AC problem
Old Aug 1, 2007 | 05:58 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default AC problem
My AC is running hot. Upon starting the car the LEDs at the controls flash for a few secs. Any ideas where to start?
Old Aug 1, 2007 | 08:06 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
The controller is telling you that there is a failure and probably a fualt code has been set.
To enter the diagnostic mode, push and hold the fan up and down arrows at the same time for about 5 seconds.
The display should show "-00".
Push "Auto" and the display will show any fault codes that are stored in the computer.
00-Not used
01-Temp. Door Motor Circuit Fault
02-Temp Door Motor Circuit Fault
03- Ambient Sensor Open
04- Ambient Sensor Short
05- In-Car Temp Sensor Open
06- In-Car Temp Sensor Short
07- Solar Load Sensor Open
08- Solar Load Sensor Short
09-Low Freon
10-UART Failure
Old Aug 1, 2007 | 08:30 PM
89 Bob L's Avatar
89 Bob L
Is the a/c clutch engaging?
Old Aug 1, 2007 | 10:37 PM
Rex Ruby's Avatar
Rex Ruby
00-Not used
09-Low Freon
10-UART Failure
OK did it, got an 09, time to see the AC tech.
Old Aug 2, 2007 | 05:38 PM
89 Bob L's Avatar
89 Bob L
If it's low on freon, this is one easy job you can do yourself. Depending on the year it is either R-12 or R-134A, or it may have been changed over to R-134A. One stop to a parts store for one or two cans of freon and an installation hose and your are all set!!!!
To AC problem
