Ignition wire change
Old Aug 2, 2007 | 09:37 AM
SPASS's Avatar
SPASS
4th Gear
Default Ignition wire change
NEW GUY HERE I have a 96 lt4 the service engine light came on i drove to a local auto zone they did a code scan a p0300 code apperared the car had an obvious missfire i looked under the hood to see if anything out of the norm stood out i saw that 1 of the ignition wires were melted from rubbing against the header i probably knocked it loose from detailing the engine bay just a couple days prior to this happening I ordered 8mm taylor wires
complete set from summit with spacers my mechanical abilities are basic at best.my question is in order for me to change the wires will i have to remove the water pump to connect the wires to the distributor from looking at it im not sure im quessing more towards yes if that be the case im not messing with it,it looks like a potential headache for myself maybe a job for the professionals ANY ADVICE WOULD GREATLY BE APPRECIATED
THANK YOU
96 LT4 BLACK ON BLACK
GS RIMS
GS FENDER FLARES
LIST OF MODS
SLP INTAKE 3 CONE [INTAKE & HEADS PORT MATCHED]
52MM BBK THROTTLE BODY
HOT CAM
AFR HEADS
HOOKER LONG TUBE HEADERS
HI FLO CATS/BORLA EXH
RIPPER SHIFT
410 GEAR
29K MILES
Old Aug 20, 2007 | 12:16 PM
pennscreek's Avatar
pennscreek
Default pennscreek
been there on my 95. you don't need to remove the water pump, just need patients and small hands. The local dealer says it should take 4 hrs. That's a lot of money! good luck
Old Aug 21, 2007 | 07:49 PM
RickF's Avatar
RickF
Just changed the wires on my 94 LT1 but should be similar. I was able to change the passenger side pretty easily from above the car; could even see the Opti. My brother (6'4" about 230) was able to do the driver side from underneath the car. He had to do it by feel as he couldn't see the opti but it worked out fine. This is about the only job we have felt was easier than the forum consensus. YMMV.
To Ignition wire change
