Air pump... wtf?
Old Aug 2, 2007 | 11:03 AM
drmrman's Avatar
drmrman
Default Air pump... wtf?
So... Awhile back I was going through my fuses and I saw one was blown. Looked it up. And it said it was my "Air pump". So I went out and spent 5 fricken dollars on a single fuse.
I put the new fuse in. Turned the car on and self destruction soon pursued!
I heard a loud screeching then a small pop. And the noise was gone. Look at the fuse. And it was blown again.
NOW FOR THE REAL QUESTION!
I am purchasing Melrose headers and I dont want to spend the 50+ dollars on the AIR fitting... Do I need it? And how do I delete the air pump? What is its purpose? Should I fix the problem?
Thanks guys!
Joe
Old Aug 2, 2007 | 11:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Arent the LT1 air pumps electric? Wonder if your pump is shot and thats whats blowing the fuse, sounds like it. Maybe an air delete bracket is in your future.
Old Aug 2, 2007 | 11:13 AM
drmrman's Avatar
drmrman
Can you go into detail on where I can get one. And why it an Air pump is even necessary on a car?... I know its an emissions thing... but is that it?
Joe
Old Aug 2, 2007 | 01:35 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I had the same problem on my 95. I just pulled the pump and any hoses attached to it and pluged the hose at the header. The check engine light will come on but it will not hurt anything. The pump is used to pump air in to the exhaust to help emissions. Before I got a PCMforless tune I removed the check engine light bulb so it would not bother me. The plug wire for the pump was left were to was and the fuse was pulled. I had no problems in doing so. No air delete bracket is needed for the LT1.
Old Aug 2, 2007 | 01:48 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I'm going with Melrose headers as well. You can remove your EGR valve and use block off plates. I found some on ebay and the have your PCM tuned to not look for the codes.sorry phone camera pics.
Old Aug 2, 2007 | 09:39 PM
drmrman's Avatar
drmrman
Thanks Jmac! The pics are a GREAT help!
When I spoke to chris at melrose he said the ERG is not integrated into the header system. Why would I need to pull and block the valve?
Joe
Old Aug 2, 2007 | 09:50 PM
STL94LT1's Avatar
STL94LT1
The EGR and AIR systems use the same piping that connects to the headers/exhaust manifolds.
Old Aug 2, 2007 | 10:08 PM
drmrman's Avatar
drmrman
Oh.........
Can anyone link me to EGR valve block offs??? And how much of a pain in the *** is it to pull it out and block it off?
Joe
Old Aug 4, 2007 | 07:47 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I got mine from this guy.
http://stores.ebay.com/Custom-Billet-Works-Inc
Just four screws to take off and put back on. And you need to plug the vac line that went to the EGR valve.
Old Aug 20, 2007 | 09:00 AM
wpsrea's Avatar
wpsrea
Who did the reprograming? Was it just the "plug-in" in the computer?
Old Aug 20, 2007 | 01:07 PM
SunCr's Avatar
SunCr
Air pump is used to help light off the O2's and CAT. The extra air creates an afterburner effect getting it to closed loop faster. On the L98's, it continues to pump air to the CAT after closed loop. It has nothing to do with EGR which lowers combustion temps and keeps your motor from holing a piston. You either have too much of a load on this circuit or there's a dead short. Inspect wiring. Otherwise, particularly if it has a lot miles, replace the motor.
Old Aug 20, 2007 | 03:03 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
PCMforless
Old Aug 20, 2007 | 09:24 PM
drmrman's Avatar
drmrman
LT1 with 50k miles. Its ok though... im just getting rid of it entirely...
Old Aug 20, 2007 | 09:25 PM
drmrman's Avatar
drmrman
PCMforless
Looks like the place to go! Everyone says great things about them!
Joe
To Air pump... wtf?
