275s vs 315s
at the track, I have been running 275-40-17s, really
like the look of y'alls cars with 315-35-17s :cool: ,
wondering other than looks is it worth buying wider
wheels? anybody seen much 60ft improvment?
thanks guys,
Wayne
92TripleBlack
Do not forget that you are adding a LOT more unsprung weight to the car, without any upgrades in power. Don't be surprised if you actually lose some time.
So if you're not spinning a 275 DR, I don't think a 315 would be worth it.
yeh spinning enough I'am beating up the 275s pretty bad, I can get 1.78s-1.82s most any time, but spinning enough I THINK could do a little better
Wayne
p.s. I know you have posted the offset thing a million + 1 times but I can't remember,
old age , any way my cars an 87 but has been conv. to 44 rear, that make any diff. about the offset?
[Modified by WG87, 10:58 AM 11/3/2001]
going to 15s ?, I'm scared of corners anyway!
[Modified by WG87, 11:18 AM 11/3/2001]
You will need spacers both front & rear, & have to grind the rear break calipers if is a newer car..
I love the way I launch..& hook up... however on the street you gotta take it easy in the corners.
Like they say you cant have it ALL if you want to fast in the 1/4 your gonna have to give up some cornering ability, if you are looking for the 1g in cornering with BIG tires all around etc.. you can expect slower 1/4 times.
Or the 3rd choice is to compromise, and NOT be GREAT in either, but "fair" in both...
As for me.. I like going from point "a" to "b" as fast as possible, so its big Drag radials, & slow in the corners..
my sway bar in in the garage.. :)
Wayne
