How do I pick a CAM
Old Aug 4, 2007 | 02:12 PM
johnny-max's Avatar
johnny-max
8th Gear
Default How do I pick a CAM
I want my 84' Vette to lobe a little at an idle, but not skake apart the already shaken apart car. How do I know what CAM I need? Are there any charts that cover this. I know they cover performance, but what about idle and sound etc. Maybe there are some here who "Just Know."
Old Aug 4, 2007 | 07:35 PM
johnny-max's Avatar
johnny-max
8th Gear
Default hummmmmm....
hummmmmmm.....
I really thought this would be an easy question fo rthis forum....
Old Aug 4, 2007 | 09:16 PM
rube1975's Avatar
rube1975
I have been doing a LOT of research on this and I am going to get http://www.lingenfelter.com/store/lpe-74220.html
It will need some other mod's nothing huge. Chip is a must. Lingenfelters book goes into great detail and is a great read; I suggest you pick up the book it will help in a number of different concepts. I picked one up at Barnes and Noble for a few bucks
Old Aug 4, 2007 | 10:31 PM
Z06_BluByU's Avatar
Z06_BluByU
The '84 crossfire injection makes this somewhat of a difficult question.. whats "lope" to some of us is considered "shake" to others.. very subjective terms.
My recommendation would be to call the comp cams tech line tell them the year, gear ratio weight of your car, and any other modifications (stall converter, exhaust etc..etc..) and they should be able to put your on the right track!
Old Aug 5, 2007 | 09:20 AM
johnny-max's Avatar
johnny-max
8th Gear
Default Thanks
I at least have a direction now to get more info.
Old Aug 5, 2007 | 09:32 AM
anesthes's Avatar
anesthes
There is no simple answer. the cam must go along with the heads, gearing, transmission setup (converter stall or stick?), ECM PROGRAMMING, intake flow, head port flow, and valve springs.
Anything over 230 degrees at .050" is gonna have a little 'lope' at idle, but also require bigger springs than your (193?) heads have, also your max lift is about .470" with the stock heads. Your intake flow probably won't want a 230 degree cam, and is it auto or stick because the stock converter is gonna bog you leaving every light.
-- Joe
Old Aug 5, 2007 | 10:25 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
This is not like ordering Chinese take out.
Old Aug 5, 2007 | 10:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
TB cars dont like large cams, they are a pain to tune.
Old Aug 5, 2007 | 03:14 PM
johnny-max's Avatar
johnny-max
8th Gear
Default Hummmm.....
May be more tha I can afford......
To How do I pick a CAM
