Super Ram Install Finally DONE!!
Pics to come, also, a tip if you wanna use a super coil with this intake, rotate it 90 degrees, and then just adjust the timing accordingly!
It ain't too pretty, but she's mine. Note the adjustment on the position of the distributor.
Yes, that is a stock TB...I don't think I need anything larger...stock cam and all.
I studded my plenum and used kep nuts from below, enlarged the runner to plenum bolt holes to 5/16" for a little more wiggle room, ground some flats on the runners for valve cover clearance with a belt sander, cleaned up all the mating surface by lapping on a piece of plate glass with some valve grinding compound.
I also built-up some of the marginal gasket surface areas on the runners with some faststeel epoxy. A long 6 mm ball end socket also helped a great deal with the runner to base bolts. The kep nuts were all accessible with an ordinary open end wrench as long as the distributor was out of the way.
With a little forethought and preparation it was no problem.
What went wrong with the installation that it took 4 times on and off? That's crazy.
Hope you didn't have to pay for all that labor at shop rates.
Now the real fun begins. I'm on tune # 183 since my SR was installed, but I like to change something just about everytime I drive the car. I guess it never ends. If you have tuning issues, I may be able to point you in the right direction.
GREAT START. I know that you will like it and feel a difference. Did you also do the intake manifold also? Replace the heads and you have a going machine.
As far as roller rockers and heads...I'm gonna wait till I'm outa school.
1. long tube headers (for an L98, this should be done before ANYTHING)
2. cam & heads package.
Then do it all at once. While you're in there, the costs will fatten. Replacment upgrades like double roller timing chain, RR's, pushrods, lifters, etc, etc, etc...............
Dead cost means what shop rate? It had to be at least $1,000 for the install. Ouch! The intake will have to be removed again anyway when the heads & cam are upgraded to match the intake.
Good luck.
Good luck.
too bad the car wasn't in SLO.
I'm close by
as well as a couple other C4 guys that are very knowledgable gearheads.
I can do the SR in my sleep now.
We could have gotten her done on a Saturday no problem.
Just provide burgers or steaks or Mo's BBQ
You will love the SR. Torque, lots of torque!
i'm also stunned as to how a shop is that severely incompetent that it took 70 hours to do a 5-6 hour job (assuming its their 1rst SR effort ever). what "deal" are you talking about? so they charged half their usual shop rate and cut the hours to 55. what they did was usurious. i would have punched the shop owner's teeth down his throat.
I bought the super ram used, it was used for 6 laps on a built motor in a camaro, before the bottom end gave out. A guy I knew bought the dead motor for the block (I guess it still was alright) and he had the super ram laying around for a while, I was talking about doing an LT-1 conversion, and I didn't wanna lose the torque, so he offered me that set up and a bunch of other stuff for $400.
The reason it took so long was because it wasn't a chevrolet mechanic, the shop typically does...dare I say...Korean cars, and the low labor rate was part of a favor. At any rate, she runs now, and I'm super excited!!
Anyone have any pictures of what that looks like under the cover?
