LT1 conversion pic,maybe
Old Aug 5, 2007 | 08:57 AM
MR NICE's Avatar
MR NICE
Default LT1 conversion pic,maybe
What do you guys think?took me long enough due to a lack of cashFAB TV cable bracket & have a chip burn is all I have to do before taking it on the road.It seems to run decent with stock chip,better than expected.
Old Aug 5, 2007 | 09:47 AM
black85's Avatar
black85
Nice work, Mr. Nice! I may do this too. Seems like a good option for those of us that don't have $1000 plus for a bolt on intake, fuel rail, etc. I'd rather put the $ in the engine!
I am curious about what your gains are w/o changing cam, rear gear and torque converter.
Is that a little in cap coil?
Dave
Old Aug 5, 2007 | 10:05 AM
MR NICE's Avatar
MR NICE
Dave, I went with aftermarket heads, cam & exhaust when i did the swap,i hope to have around 375 @the crank.the Dizzy is large hei.Stock converter, 3.07 gear,it should be ok but I may get a converter down the road.
Old Aug 5, 2007 | 11:10 AM
87 rag's Avatar
87 rag
Looks great.
I like what you did with the fuel lines,pressure regulator and guage.
I've been gathering parts for my swap for a while now and still need to put together a plan for my fuel lines. Were there any obsacles that were tricky to overcome with the way you ran them?
Old Aug 5, 2007 | 12:05 PM
arkangel81's Avatar
arkangel81
those fuel lines do look SWEEEET
Old Aug 5, 2007 | 12:51 PM
MR NICE's Avatar
MR NICE
Originally Posted by 87 rag
Looks great.
Very simple,bolted afpr to air pump bolt,used earl's fittings to convert stock feed and return lines to 6 an,weld 2, 6 an male fittings to fuel rail, 90* and straight, may vary depending on your dizzy,I can send you detailed pics if you want them.For safety reasons I will remove the gauge and install a plug after I get it tuned.
Old Aug 5, 2007 | 02:48 PM
DrEvil11417's Avatar
DrEvil11417
Originally Posted by MR NICE
Very simple,bolted afpr to air pump bolt,used earl's fittings to convert stock feed and return lines to 6 an,weld 2, 6 an male fittings to fuel rail, 90* and straight, may vary depending on your dizzy,I can send you detailed pics if you want them.For safty reasons I will remove the gauge and install a plug after I get it tuned.
What size are the stock TPI fittings?
Old Aug 5, 2007 | 05:15 PM
87 rag's Avatar
87 rag
Detailed pics would be fantastic.
Please send them to jcowan@delawana.com
Old Aug 5, 2007 | 07:48 PM
MR NICE's Avatar
MR NICE
here is a pic of fittings,Return line is,14mm female to 6an female,Feed line is 16mm female to 6 an female.
To LT1 conversion pic,maybe
