Gasket Part Numbers
Old Aug 5, 2007 | 01:34 PM
KDuniverse's Avatar
KDuniverse
Default Gasket Part Numbers
I'm looking for a set of Fel-pro head gaskets for my repair. 93 LT1. Anyone have a model number? I was told to use the Impala SS ones, but was looking at sticking with the Fel-pros. Also, looking for the exhaust manifold and intake manifold gaskets as well. Which RTV is preferred?
Old Aug 5, 2007 | 01:44 PM
STL94LT1's Avatar
STL94LT1
I've ran the Imp SS head gaskets for five years without a problem. The Imp head gaskets will also give you about 1/2 point compression ratio gain.
Old Aug 5, 2007 | 01:50 PM
86PACER's Avatar
86PACER
Head gasket- FEL-PRO Part # 9966PT
or
FEL-PRO Part # HS9966PT2 - Comes with head gaskets plus intake gaskets, exhaust mainfold gaskets, valve cover gaskets, and throttle body gasket.
and if you want their head bolt kit, that's FEL-PRO Part # ES72856. One per head.
Use this for sealant:
To Gasket Part Numbers
