HELP with stubborn bolt!
Old Aug 5, 2007 | 05:00 PM
canoeman's Avatar
canoeman
Default HELP with stubborn bolt!
I'm trying to replace my injectors in my 89. Everything is off almost except the front passenger side bolt that holds the fuel rail down. It got it's points rounded and now I don't have what I need to get it out. The runners are still in and you can't go straight down to get at it. There is only about a 1 inch clearance between the bolt and the runner, so it will have to be from the side. Would anyone have a quick and easy way of getting that loose? If I have to buy it, so be it, I just want to get it moving.
Thanks in advance,
Bill
Old Aug 5, 2007 | 05:55 PM
86PACER's Avatar
86PACER
Can you get a crowfoot socket in there?
Old Aug 5, 2007 | 05:57 PM
canoeman's Avatar
canoeman
It won't do any good, it won't be able to grab enough to turn it. This bolt is tight.
Old Aug 5, 2007 | 07:11 PM
evmlarry's Avatar
evmlarry
Get that runner loose, get your torx on a long extension, and pound the hell out of it with a hammer to get a good fit. Slowly turn it while hitting it good and hard with a hammer. <--- It'll work if it's not too rounded out. Else plan on extracting.
Old Aug 5, 2007 | 07:24 PM
cmontel727's Avatar
cmontel727
I would soak that bolt with PB blaster or your favorite penetrating oil then use one of those nifty rounded bolt head tools sears sells. Also I would loosen the runner to get a straight shot at the bolt head.
Worst case scenario I would use vise grips and a hammer.
Hope this helps
To HELP with stubborn bolt!
