AIR pump eliminator question
Old Aug 6, 2007 | 01:35 PM
Lieutenant 804's Avatar
Lieutenant 804
Default AIR pump eliminator question
I bought an AIR pump eliminator from MAM, put it on and now my serpentine belt is too loose. The tensioner is maxed out. In the catalog it says "Best of all, You can use your original serpentine belt" but when I called they admitted that the original belt will no longer work. Then to add to the customer satisfaction, they don't know what size belt is needed.
Has anybody gone through this already and possibly know what belt size is needed?
Many thanks in advance.
Old Aug 6, 2007 | 01:49 PM
8888vette's Avatar
8888vette
Default belt
take some rope and place the rope aruond all the pulley that it need to go to with some tension and then measure the rope that will give you and idea of the size you need
Old Aug 6, 2007 | 03:00 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Or you can use a cloth tape measure, wrap it around to get the inch size then go and match
Old Aug 6, 2007 | 08:02 PM
CRV3TT3's Avatar
CRV3TT3
i made my own and took the original belt and wrapped it around all the pullies and cut it to length, measured it, went to autozone and got the right length belt!
Old Aug 7, 2007 | 08:16 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
the MAM one must be different. I have the BPP elim pulley and ive always been able to use stock belts.
Old Aug 7, 2007 | 12:42 PM
Corn Flakes's Avatar
Corn Flakes
They admitted it no longer worked? That can't be good for business. They sell shorter belts for there off road pullies. You could try that one or atleast ask them about it.
To AIR pump eliminator question
