Air Conditioner Cycling Question
My '89 Ebay rat runs perfectly with one odd exception related to the air conditioner which I have had since I rescued the car from its previous owner. When I use the air conditioner and the car is stuck in traffic, the temperature will ultimately creep into the upper 220 range, notwitshtanding the fact that the cooling system is in top notch condition, both fans are running etc. (I usually shut it off before that point). Yet, when I am moving along the temperature drops into the mid to high 180s with the air on. Without the air on the car runs in the low 180s, high 170s traffic/no traffic---GREAT. I have noticed that the air conditioner compressor clutch is not cycling/engaging on and off, but that the compressor runs continuously with the air on. This leads me to wonder whether that could be the source of the unusual temperature variance with the air on and the car stopped. Has anyone had a similar problem? I will replace the cycling switch in any event, but wanted to ask first.
Keep on surging!
/s/ Chris
Keep on surging!
/s/ Chris
Flushing the system does a good job with lowering engine temps. In addition, check your serpentine belt to make sure it is not too old and shiney.
2. if the A/C is selected to 60 degrees, the A/C is the same as a regular ol GM car, in that in the lowest seting, the fan motor revs a little higher, the recycle door is open, and the outside air is shut off.
The compressor cycling is stopped, and it runs continuously until the A/C selector is moved off the lowest selection possible.
The ECM uses a signal from the high pressure side of the a/c system to ground the main fan relay. A switch, on that line, opens at 230 psi, and the voltage rise at the ECM tells it to ground the Relay. That switch recloses at 190 psi, at which point ground is removed from the relay and the fan should turn off. Pressure is heat and it is dependent upon the outside air temp - high temps - higher pressures - so if it's 90 degrees or better, the fan is going to be running anytime the vehicle isn't moving. Ditto for your compressor - the cycling switch cuts power whenever the pressure is low enough to freeze over the Evaporator. The lower the outside temp, the lower the pressure/temp of the fluid being metered into the core. If it's 70 or above, the low side shouldn't be dropping to the cutoff threshold so the compressor will always be cranking.
As to operating temps, the more that coolant fan runs, the lower the temp at the radiator and in general, a/c turns that fan on a lot sooner and runs it a lot longer than if it were off.
Every car I've owned runs cooler with the a/c on - my '89 about 205 to 212 - and having owned it since it was new, I know that's how it rolled off the Dealer's lot. Should I turn off the a/c, it'll climb to 226 and then cool to 217/220 before cycling the fan back off and repeating the process, so I gain a couple of degrees with the a/c on.
Yours looks close to spec, but I'd be curious as to why both fans are running. In fact, my experience with running both (I had to try it back in '90 as it was the "hot thing" to do), is that it simply overwhelms the alternator and as the voltage drops, the fans slow down. And that causes the coolant temp to creep up at idle (along with the temp of the air out of the vents). I'd try yours with just the one fan and see if it doesn't gain a few degrees or if not, keep an eye on system voltage as dropping below battery can also cause driveability issues.
/s/ Chris
