Should the nipples coming from the throttle body be plugged? If so, how? Basically you are just extending the hose from the passenger side over to the drivers side hose, correct? Thanks for your assistance
I dont know how many coolant lines are in the LT TB, but Im assuming two like most. Cut both of them, get a metal nipple, some hose clamps and connect them. You may need a piece to connect, take note of the shape and head to your local auto parts, they probably have something in the way of a preformed hose that you could cut at different points to make it work .
