Superram, passenger valve cover
Old Nov 4, 2001 | 04:19 PM
RocketSled's Avatar
RocketSled
Default Superram, passenger valve cover
Okay, so I've got most everything going back together, then I get to the point where I need to reinstall the passenger side valvecover. I can get the bugger on! There seems to be a clearance problem where the gap between the #2 valves and the SR runners isn't wide enough to get the cover on.
After wrangling with it for 20 minutes, It's obvious where the interference is as there's valve cover shavings :eek: on the tops of the rockers! Time to Clean up-come in-and-ask y'all!
Old Nov 4, 2001 | 04:28 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: Superram, passenger valve cover (RocketSled)
You need to cut that valve cover so it matches up with the runners.
Take a die grinders and grind away so it slips in
Old Nov 4, 2001 | 04:32 PM
RocketSled's Avatar
RocketSled
Default Re: Superram, passenger valve cover (L98Terror)
Are the valvecover's magensium?(sp) Do I need to be careful about that?
Old Nov 4, 2001 | 04:33 PM
scorp508's Avatar
scorp508
Yes they are. I wouldn't get them TOOOOO hot. ;)
Old Nov 4, 2001 | 04:45 PM
L98Terror's Avatar
L98Terror
Stock Covers?
Hold on I'll snap a shot of my old ones
Old Nov 4, 2001 | 04:50 PM
L98Terror's Avatar
L98Terror
I looked I don't think I used my stock covers with the SR
But on smallblocks car I ground it through the outside layer
also try rotating the valvetrain sometimes a rocker arm could be in the way
Old Nov 4, 2001 | 06:09 PM
ralph's Avatar
ralph
fit ok on mine. just had to cut off the drippers. Sometimes however the passenger can be a bitch to get back on. I have to push it hard toward the rear. I think the breather baffle gets caught on one of the rockers. but eventually it will go on.
Old Nov 4, 2001 | 06:11 PM
AS84's Avatar
AS84
Mine were a pain to get on. With a little grinding I got them on. As it was said above grind the valve covers to match the runners. Don't take too much though.
Old Nov 4, 2001 | 06:41 PM
RocketSled's Avatar
RocketSled
Default Re: Superram, passenger valve cover (AS84)
YOUZ GUYS ARE THE GREATEST!
:cool: Gotta love 'dem benchgrinders! (like 12 seconds of grinding, problem solved!)
To Superram, passenger valve cover
