need help.... Runner cracked
Old Aug 10, 2007 | 07:14 PM
85WHITEZ51's Avatar
85WHITEZ51
Default need help.... Runner cracked
So the runners I waited for over 3 months on back order finally came in. While torque them down one cracked on me.
They are the edelbrock high flow runners (Aluminum). It cracked on the drivers side runner where the mounting bolt goes at the very top on the right side of the runner. I was really suprised it happened as I only had 20 foot pounds on the trq wrench. The runner basically hung on the fuel rail :-(
Can I JB weld the crack or solder it (exterior part)? If this wont work and it has to be welded any suggestions on where I could go (Austin TX)? It hasn't affected it structurally but I don't want to have a chance for a leak.
If needed I can get picks tomm.
Old Aug 10, 2007 | 08:10 PM
Muffin's Avatar
Muffin
Any welding shop should be able to weld it. You will have to work the welded surface so it is flat. I broke my AC mount,took the guy about 10 minutes to fix it. Cost me $10.00.
Old Aug 10, 2007 | 08:16 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
get a real weld and grind/file flat.
Old Aug 10, 2007 | 08:40 PM
chucks88's Avatar
chucks88
I'd let edelbrock know
Old Aug 10, 2007 | 08:45 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I agree - let them know and maybe they'll replace it.
Old Aug 10, 2007 | 11:49 PM
staugur's Avatar
staugur
tell them it arrived broken and sue UPS
Old Aug 11, 2007 | 12:17 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default sue happy
remind me never to send you anything!!!!
Old Aug 11, 2007 | 01:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
He admitted to it hanging up on the rail, why would it be Edelbrocks baby?
Old Aug 11, 2007 | 09:26 AM
chucks88's Avatar
chucks88
I missed that when I first read it.......I would have thought that the threads would have stripped out before a crack appeared.
Old Aug 11, 2007 | 10:03 AM
engle1147's Avatar
engle1147
You broke it you - you fix it.
Get it repaired and reinstall it with a little more care. These things happen - don't sweat it - fix it or replace it and move on.
Old Aug 11, 2007 | 12:37 PM
85WHITEZ51's Avatar
85WHITEZ51
Thats kind of where my mind was at. Granted at 20 pounts of trq with alm threads it "shouldn't" crack but it was my bad for not checking the clearances before clamping down. Learned my lesson on working on the car at 3am.
Thank you everyone for the advise. I'll pull them off and take it to a shop to weld.
To need help.... Runner cracked
