C5 brake conversion for 85
Old Aug 20, 2007 | 04:12 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by BerniesVette
Where is the best place to get C5 calipers?
Bernie
They can be had really cheap in the C5 parts section some times. As low as $25. FLY LOW had some for $175 shipped, new with pads, you could try him.
Old Aug 20, 2007 | 04:16 PM
BerniesVette's Avatar
BerniesVette
Thanks Ardwolf!
Bernie
Old Aug 21, 2007 | 03:50 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
C5 Z06 caliper
C6 base/Z51 caliper
Old Aug 21, 2007 | 04:26 PM
firstvette 2's Avatar
firstvette 2
Default Brakes vs Wheels
Conversion sounds good. Will my 17" sawblades fit over the new calipers and rotors? 91-C4
Old Aug 21, 2007 | 05:57 PM
Aardwolf's Avatar
Aardwolf
No, the saw blades do not fit.
Old Aug 31, 2007 | 10:08 AM
firstvette 2
Any idea of what wheel options I need to get larger/better brakes on the front?
Old Sep 1, 2007 | 05:17 PM
LD85's Avatar
LD85
Progress, painted them w/RED & Black Caliper paint and left the lettering silver, then clear coated w/1200-degree clear
Old Sep 2, 2007 | 04:12 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Looks great. I modified my bracket design so I could retain the heat shields. Supposedly these keep the rotors from cooking the ball joints and everything else.
Either that or they keep water off that side of the rotor, but the gap is much bigger than with the stock brakes.
Old Sep 2, 2007 | 07:30 AM
LD85's Avatar
LD85
Thanks, the paint looked good and the clear coat kicked up the gloss a bit
Is there interference with the heat shield on the 85?
Old Sep 2, 2007 | 12:27 PM
red86vet's Avatar
red86vet
Acct suspended by request 6 November 2012
I am using the 17" saw blade wheels with the C5 brake conversion on my '86 with no current issues. The car is used for autocross and track sessions.
Old Sep 2, 2007 | 01:53 PM
CentralCoaster
The heat shields bolt to the knuckles, but your brackets are going to hog all the real estate. Probably not worth messing with unless you've got a bandsaw in the garage. Or maybe you could modify the heat shield itself. Some use them to attach a brake duct hose to.
Old Sep 2, 2007 | 02:19 PM
LD85's Avatar
LD85
Cool , IO just trimmed my shield with tin snips
does the brake pad wear indicator go in our out or does it matter?
Old Sep 2, 2007 | 02:39 PM
  #33
CentralCoaster
Not sure. My front bumper is the wear indicator on mine.
Old Sep 2, 2007 | 05:18 PM
  #34
LD85's Avatar
LD85
The new C5 pads came with the non-indicator pad,,, having a nice black matte finish on it and the pad with the indicator had palin steel,, I assumed that the matter finish was to point outward,,,, so it is.
Thanks for your help, they are on and loooooking goood!
Old Sep 2, 2007 | 06:18 PM
  #35
Dominic Sorresso's Avatar
Dominic Sorresso
Larry,
What paint did you use for yours?
Old Sep 2, 2007 | 08:09 PM
  #36
LD85's Avatar
LD85
Originally Posted by Dominic Sorresso
Larry,
Autozone 500- degree Red Engine Paint - aerosol
VHT 500- degree Gloss Black Caliper - aerosol
Aerosol Engine Paint 1200-degree Ceramic Clear - aerosol
Old Sep 2, 2007 | 08:45 PM
  #37
LD85's Avatar
LD85
Is this rotor rotation pic correct? Its from the Electro-Dynamics.com web site
To C5 brake conversion for 85
Old Sep 2, 2007 | 10:13 PM
  #38
LD85's Avatar
LD85
Found this
Old Sep 3, 2007 | 12:57 AM
  #39
CentralCoaster
Yup that's right. I've also seen someone post rotor temps from their C6 Z51 (with factory backwards rotor on one side) and the correct one did cool better.
Interesting though, that I spun it by hand both directions and it seemed to move more air when installed backwards. Maybe I wasn't spinning fast enough. Most centrifugal fans use forward curved blades though. Go figure.
Old Sep 3, 2007 | 02:24 AM
  #40
LD85's Avatar
LD85
Well when you think of how and end mill works on a milling machine, the vanes would look like the elctro-dynamics pic
