Removing Heads
Old Aug 11, 2007 | 12:34 PM
KDuniverse's Avatar
KDuniverse
Default Removing Heads
There's a crossover from one head to the other on the rear of each. There's one bolt that goes into a "block" of aluminum and from there into the head, and a tube that runs to the other block/head, etc. This one bolt is crippling me. I can't get it loose for the life of me. Any idea how to break this free? Electrolysis is apparently an issue.
Old Aug 11, 2007 | 03:27 PM
aboatguy's Avatar
aboatguy
The crossover tube is a biyotch to remove in the car. After removing/installing 2X in the car I've been pulling them on the engine stand (its easier) I use a little bit of anti-seize on the threads during install IOT preclude problems like yours. Since you have one off, I'd remove the head with the line attached and work on it on the bench.
Mike
Old Aug 11, 2007 | 04:30 PM
KDuniverse's Avatar
KDuniverse
I don't have either off yet. Pain in the ***. Plus, it's raining, so I'll take a break for today, and try again tomorrow.
Old Aug 11, 2007 | 04:39 PM
aboatguy's Avatar
aboatguy
Oh so you are removing them in the car, I can empathize.
The through bolt is hollow, and the banjo is sealed with a special washer on either side of the banjo, the washers are pricey (I believe they were about 7 bucks a pop) so watch where they fall. I'll post some pics of the assembly in a few minutes, it may help you in the removal process.
Mike
Old Aug 11, 2007 | 05:36 PM
KDuniverse's Avatar
KDuniverse
thanks a lot.
Old Aug 12, 2007 | 02:49 PM
fredk's Avatar
fredk
I cut the tube before I took the heads off and purchased another one. It was a different design so I had to reroute with rubber hose.
Fred
Old Aug 13, 2007 | 06:18 PM
KDuniverse's Avatar
KDuniverse
I ended up cutting the tube. figures the friggin thing is discontinued though. I gotta find another with good bolts.
Old Aug 13, 2007 | 07:54 PM
aboatguy's Avatar
aboatguy
The couple of times I did H/C swap in a C4 that tube was the biggest PITA.
Now I just pull the entire engine, with the help of either of my two kids I can get the engine on a stand in an afternoon, reinstallation is just as quick.
If your local salvage yard can't order the tube try Vette to Vette or Dino's corvette salvage
Art's Corvette parts may have it used for your 93 but he still has the 95-96 ones new. I beleive you can buy the newer one and cut it down to work on your 93. (if I my memory is correct on the differences between scranages 92 and my 95....but its been a while ).
Mike
Old Aug 13, 2007 | 08:18 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cut line
i would recommend that you flare the line, and add a fitting in the middle somewhere, so the next time, all you have to do is remove the union in the middle. so don't throw it out, repair it!!!!
Old Aug 13, 2007 | 09:26 PM
KDuniverse's Avatar
KDuniverse
I was thinking about just running a piece of rubber tubing in between and hose clamps on either end.
Old Aug 14, 2007 | 03:31 PM
coupeguy2001
Default hose
that will work also, but you have to put a bulb into the line so the hose won't blow off.
try the tubing bulbers at home depot or lowes, and see if they might be close to the right size to make the tube swell enough to hold the clamp/hose.
Old Aug 15, 2007 | 08:24 AM
dan0617's Avatar
dan0617
That is an awesome idea!!!
To Removing Heads
