PCV Location 1995 lt1?
Old Aug 14, 2007 | 08:19 AM
stormy649's Avatar
stormy649
1st Gear
Default PCV Location 1995 lt1?
Good Morning: You would think that after owning 7 vettes over the last 62 years that I would know this! I bought the chiltons book but my eyesight is not the best.
Anyone know what side of the 1995 LT1 manifold is the pcv and best way to get to it? Thank you. Stormy
Old Aug 14, 2007 | 08:21 AM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I have a 94 and it should be likewise - on the left side (drivers)
Old Aug 14, 2007 | 08:23 AM
Mekanic's Avatar
Mekanic
in the intake manifold on the drivers side.
remove fuel rail cover and its in the middle area, and the hose is more of a PITA to RR than it should be
Old Aug 14, 2007 | 08:39 AM
shop14's Avatar
shop14
driver side intake
Old Aug 14, 2007 | 03:58 PM
ebusa's Avatar
ebusa
Old Aug 15, 2007 | 08:25 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be careful you don't break your plastic vacuum line trying to get that PCV hose off. They tend to get "baked" in there and are often hard to unseat.
I used a pair of locking pliers wrapped in a shop towel (to prevent cracking the rubber hose) to coax mine out.
A shot of PB Blaster or WD-40 around the base of the valve for 10 minutes or so prior to removal would be a good idea, too.
To PCV Location 1995 lt1?
