Checking TPS voltage with a voltimeter?
Old Aug 14, 2007 | 12:32 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Default Checking TPS voltage with a voltimeter?
I would like to check my TPS voltage but when the TPS connector is plugged in, none of the sensor's contacts are exposed for me to probe. What is the normal way to check TPS voltage with a voltimeter?
Old Aug 14, 2007 | 01:00 PM
Aardwolf's Avatar
Aardwolf
I stick pins in the back of the connector then attach 'gater clips.
Old Aug 14, 2007 | 01:04 PM
RRT vette's Avatar
RRT vette
That is the best way. You can straighten a paperclip and cut to the right lengths and connect alligator clips.
Old Aug 14, 2007 | 01:35 PM
LouisvilleLT4
Cool, I will have to find out more about these "alligator clips." Where do I get them?
Old Aug 14, 2007 | 01:37 PM
Aardwolf's Avatar
Aardwolf
They are very cheap, just wires with teeth on the end that spring closed. Even Walmart has them. You could wrap or solder a wire onto the pin if you don't want to go to the store.
Old Aug 14, 2007 | 01:47 PM
LouisvilleLT4
It's pretty tight inside that TPS sensor, do you think there's enough room to stuff these into it without them shorting each other out?
Old Aug 14, 2007 | 02:40 PM
Roger anderson's Avatar
Roger anderson
I just check mine last friday. If the points are sharpe on your meter probes you can puncture the wire insulation and make contact.
Old Aug 14, 2007 | 02:43 PM
Aardwolf's Avatar
Aardwolf
I mean wrap the wire and tape it around the stick pin and put that into the back of the connector, or solder a wire onto the pin and stick that into the back of the connector. I have a few sets of 'gator clips, they come in handy. But if I didn't want to go to the store, I would just make a tester.
Old Aug 14, 2007 | 03:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I use a couple of 1 1/2" brad nails(flat finishing nail for air nailer). Lay it on the wire, then slide it under the rubber insulator, till it reaches the metal part of connector. Once both are in, I put one probe on each and measure the voltage.
Old Aug 14, 2007 | 04:13 PM
staugur's Avatar
staugur
Ecklers has a connector you just plug in to check this.
Old Aug 14, 2007 | 04:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
In the "old days" they were more commonly known as "roach clips"...:o
I prefer to use the jumper wires that can be bought at Radio Shack as they have insulators over the clips on either end of the wires. You can get a variety pack for a copla bucks.
Old Aug 14, 2007 | 04:47 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
One million and One uses.
Old Aug 14, 2007 | 05:16 PM
idcard's Avatar
idcard
You can make a test gig yourself. Look at the one listed in the Eckler's catalog, then go to a junk yard and remove the TPS with the plug attacked. I cut the TPS off right after the flat portion and soldered on post and the wires from the plug. It is real handy and you can be assured of a good meter connection for a reading that isn't jumping around because of loose connections.
Old Aug 14, 2007 | 05:26 PM
LD85's Avatar
LD85
[QUOTE=65Z01;1561497124]In the "old days" they were more commonly known as "roach clips"...:o
QUOTE]
Along time ago, far far away!
Old Aug 14, 2007 | 05:35 PM
geezel's Avatar
geezel
Old Aug 14, 2007 | 06:42 PM
LouisvilleLT4
I just did this. So easy!!! Thanks. Turns out my TPS works fine.
Old Aug 15, 2007 | 05:52 AM
Roger anderson
Your welcome, mine was at .67 volts I adjusted it to .54.
Old Aug 15, 2007 | 07:23 AM
Tom Piper's Avatar
Tom Piper
Go to Autozone and let them read it with a scan-tool.
I think Autozone will do it for free.
Tom Piper
Old Aug 15, 2007 | 08:41 AM
JamesRS's Avatar
JamesRS
Corvette Enthusiast
Some interesting information for what it's worth. I checked my TPS voltage with a volt meter about two weeks ago and set it to .526 volts. Then I connected my WINALDL and checked to see what the ECM indicated the voltage was and it said the voltage was .490 volts. I figured this was probably from connector fatigue. I also figured since the ECM thought the voltage was low, then it would be best if I set it to where the ECM saw .53 volts. I adjusted the TPS again watching the voltage through the WINALDL software and once it was at .53 volts I locked it down.
To Checking TPS voltage with a voltimeter?
