Starter Removal
Old Aug 13, 2007 | 08:49 AM
Vision2279's Avatar
Vision2279
Default Starter Removal
Okay here's another one for you guys. Since all of you have been such a great help in the past I figured I'd give you another one.
The starter on my 85 has been acting up. Every now and then it won't start right up. You'll hear it click a few times and then it will turn over. So in an effort to get it tested I want to get it out of the car. The problem is, looking at my Chilton's manual, it's directing me to rip out the exhaust and a few other things which, needless to say, will put the car down and out for a little while.
The question is, is there an easier way to get the started out without having to pull out the exhaust pipes and other things in that area?
Thanks,
Vision
Old Aug 13, 2007 | 09:08 AM
89 Bob L's Avatar
89 Bob L
You do not have to pull out the exhaust. It is a tight fit, but you can do it.
remove the battery cable.
Remove the Transmission shroud.
Remove the two bolts holding the starter to the block.
Remove the wires to the selenoid.
check to see if you have any shims between the starter and the engine.
Old Aug 13, 2007 | 09:23 AM
Vision2279's Avatar
Vision2279
Cool. Thanks for the reply. I'll give that a shot!
Vision
Old Aug 19, 2007 | 03:04 PM
Tracker's Avatar
Tracker
This is the plunger inside the starter. It corrodes and collects dirt from the starter brushes. That is why you get that 1 click and then it starts. The "CLICK" clears away the dust and dirt. Removeing it is very easy,first remove the starter from the car. Two bolts and two wires and the starter is free. After the starter is out, remove the cap that is in the picture below. Then clean the plunger, where the screwdriver is pointing to. I used a Dremel tool to clean mine with a wire brush in it.
[IMG][/IMG]
Cap is removed by 3 little bolts and you have to take the 2 terminals off the starter also.
[IMG][/IMG]
Clean the inside of the starter where the plunger makes contact across the terminals. Piece of cake to do and you should be good for about 3 more years. Best part of this repair. NO COST in parts.
That is rare in a corvette repair.
[IMG][/IMG]
Old Aug 19, 2007 | 03:13 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Excellent post, I will try this if I ever get fed up enough with my "one click" starting.
OP, I would strongly recommend removing the wires before unbolting the starter, otherwise the starter will fall down and try to snap the wires. Other than that, this is a pretty self-explanatory job, just unbolt it and bolt it back on when you're done. Be sure to use safe practices when raising the car.
Old Aug 19, 2007 | 05:12 PM
89 Bob L's Avatar
89 Bob L
Nice TIP!!
Old Aug 19, 2007 | 06:07 PM
86PACER's Avatar
86PACER
I'm having this same damn symptom with my other car. But I've found that if I just jump battery voltage directly to the solenoid from under the car with a peice of wire, it starts everytime. If I go into the car and try with the key, just a click.
Old Aug 19, 2007 | 08:55 PM
frankburns's Avatar
frankburns
Another idea is to use a jack stand under the starter so is won't hang up on the wires. This lets it down a few inches and makes getting to the connections a bit easier. also some GM's still have a rear mounting assembly. If it has the rear mount with the nut just loosen the nut and lift up the back of the starter and it will come up and out of the bracket, no need to remove the bracket.
If you end up buying a new starter spend the extra money for a new one, or better yet take yours to a local shop and have it rebuilt, better quality control. I recently changed starters and had to go through 3 different remanufatured starters before I got one that worked. All three had a different length pinion gears.
Old Aug 20, 2007 | 01:00 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default starter
I agree with everything 89 bob L said
but take off the fuel filter also. remove the gas cap first.
the starter gets rotated about 180 degrees, and it slips out.
wierd how you have to take off the torque converter pan, but you have to.
The starter on the corvette in 85 has a longer solenoid, but the starter on 86-88 has a shorter solenoid with the longer brass contact tube.
If you end up buying just a solenoid because the old solenoid's internals are fried, make sure you sort of put your solenoid back together when you go to buy a new one to compare it with.
If someone has already changed your starter, you may or may not have the right solenoid that the books will show, and you might have to take the new solenoid back to get the right one.
To Starter Removal
