what cat is high flow?
Old Aug 13, 2007 | 08:16 PM
f451degrees's Avatar
f451degrees
Default what cat is high flow?
going to replace my cat and add corsa exhaust on my 91 vert. probably gut or elim the pre cats, no headers for now.
cat's run from $50 to $250. How do you know which ones will flow the best? If the $50 one flows the same as the $250 one, I'll go with the $50 one, because I am a cheap skate.
Old Aug 13, 2007 | 08:20 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
The cheapest GOOD high flow cat I found for our cars was the Carsound (Magnaflow) universal cat with 3" inlet/outlet. Get it welded on.
Old Aug 13, 2007 | 08:46 PM
Chatman's Avatar
Chatman
This is one you have to research high and low. You will see misinformation and the same cat priced from $280 to $80. The fact that a dozen websites all point to the same source ultimately doesn't much help.
I bought a Magnaflow (Car-sound) direct fit for our Volvo and was satisfied but not especially impressed. At least it was in a box marked as a Magnaflow. They don't have a direct fit for the Corvette do they?
Old Aug 13, 2007 | 11:16 PM
f451degrees
Not sure, but will look.
thanks for the replys.
tom
Old Aug 14, 2007 | 04:08 AM
ToniH's Avatar
ToniH
I sure hope they do as I just bought and received one for my 91.
Lets see....this one: http://www.ecklers.com/product.asp?p...&dept%5Fid=157
BTW. you can see light shining through it
Old Aug 14, 2007 | 07:17 AM
Kool88vette's Avatar
Kool88vette
I got one welded on. I just bought a stainless steel mandrel bent 2 1/2 front Y pipe from Exotic Muscle. It cost $195.00 and It has no pre cats. I had to keep my stock shorty headers because of California smog laws.
Old Aug 14, 2007 | 08:08 AM
black_89_vette's Avatar
black_89_vette
Don't go ebay cheap.
That's what I ended up doing cuz I needed to pass emissions and I thought a high flow cat were all the same.
I took it to a dyno and over 4000 rpm, I only made 15 hp. Flat out, those cheap "hi flow" ebay cats couldn't flow past 4000 rpm.
I got a set from TJWong (forum member). Dynomax 2 3/4" and I like them already without dynoing it. They sound good too.
www.inthehook.com/Jerry/may042007.wmv
Well, the 383, Flowmasters and Hooker headers help that too.
Old Aug 14, 2007 | 08:15 AM
BADDUCK's Avatar
BADDUCK
So is it louder without the precats? I have more decel sound now.
Old Aug 14, 2007 | 08:44 AM
Mekanic's Avatar
Mekanic
*COUGH*straightpipe*COUGH*
Old Aug 14, 2007 | 10:17 AM
Kool88vette
I'm sure it will be louder but I haven't installed the front Y pipe yet. I'll let you know how it goes.
Old Aug 14, 2007 | 10:22 AM
Kool88vette
The Magnaflow Carsound Cat that I installed was a universal fit. It has the 3" inlet. It flows much better than the stock converter. I had Magnaflow catbacks installed at the same time.
Old Aug 14, 2007 | 11:51 AM
rickneworleansla's Avatar
rickneworleansla
It's because of all the corvettes running around without cats that you have that bad cough?
Old Aug 14, 2007 | 12:07 PM
ToniH's Avatar
ToniH
I today received my Corsa too and tried how the MagnaF/carsound cat fits in that end. Seems to fit nicely. Haven't tried the front Y side yet. But, the box says its direct fit to 91 Vette, so I hope it does.
Here is the Corsa rear Y + MF/Carsound cat
To what cat is high flow?
