Fuel pump runs constantly?
I'm sort of new to this whole fixing up cars buisness but I learn quick and my dad is a big help.
I just got it so I still need to go out and buy fuel pressure gauge and a diagnostic tool so I can read error codes but I figure Id toss this out there to see if anyone has any ideas.
When the car is running the fuel pump never seems to shutoff I can hear is running constantly if I'm outside the car listening for it or if I touch the gas tank lit I feel it vibrating rapidly. You can smell that the car is running rich from behind the car and if you open the hood it smells like gas.
Also not sure if its related or not, this is an intermittent problem that doesn't *seem* to be affected by temperature or anything else but sometimes if you hit on the gas "hard" 2.7k+rpms the engine missfires its intermittent so its really a pain sometimes it will run great then 2 minutes later misses its really the only "serious" problem I have with the car right now and once I get these problems fixed its upgrade time.
Thanks for any help
-Chris
If the vacuum line is connected, see if there is any evidence of fuel in it when you pull it off the regulator. Fuel there indicates the diaphragm has failed in the regulator, good luck.
I would go ahead and make sure the car is sound mechanicaly before worrying too much about the interior. The missing could be from a few things. You may need new plugs and wires or the injectors might be in need of replacing. You can ohm the injector coils to see.
You won't need a diagnositc tool unless you want to scan the engine with a laptop and cable. To pull the codes just use a paperclip and purchase a FSM (factory service manual).
