Stalling... but only on turns... hm...
Old Aug 15, 2007 | 09:17 PM
bogus's Avatar
bogus
Originally Posted by LouisvilleLT4
I've had this happen before. Turned out to be an empty gas tank.
Ok, I'll stop.
sigh.
Old Aug 15, 2007 | 11:01 PM
hippy's Avatar
hippy
Originally Posted by hippy
I'm not sure if I understand your original post correctly. Did the car act up AFTER filling it up? My car turns to sht about 1 bar below half already. I know not to hammer on it (not that I would on the streets) around people when the gauge gets to that point cause it acts up.
If it did act up on a full tank that's a different story. If it didn't on a full tank but did on a 7 gallon tank I will go with poor fuel pickup.
Well? How about an answer to this post.
Old Aug 16, 2007 | 12:23 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
TPS sensor is going bad, IMHO. It wont always put a code out. Can you check the voltage from idle to WOT?
Old Aug 16, 2007 | 02:32 AM
bogus's Avatar
bogus
oooh... TPS... I hadn't thought of that one. I will check voltage tomorrow. I can check voltage... just turn on the key and not start it.
I am also thinking a bad ignition switch... but TPS does make sense. It cuts out all hell breaks loose. And it would wig out the EBCM...
And yes, Hippy, it wigged out with a full tank.
Old Aug 16, 2007 | 11:21 PM
bogus's Avatar
bogus
I ordered a new TPS and ignition switch... they weren't all that expensive... so a little PM could save me a ton in diagnostic time.
I still think the alternator is a bit suspect, but time will tell...
Old Aug 16, 2007 | 11:27 PM
steve40th's Avatar
steve40th
Just remember the TPS will be reset automatically when you start the car, as it resets to 0. I just unplug it, take it off slowly as the Orange spongey thingy behind it falls easily, then replace. Of course some recommend disconnecting the battery
The ignition switch I have never done, but the whole column was redone and I needed a new key.
Old Aug 16, 2007 | 11:29 PM
bogus's Avatar
bogus
the TPS is easy on the LT1! you are right, no adjustment needed.
The switch is pretty straight forward... drop the column off the dash and it's right there.
Between them, they were only about $45. and that's for GM parts.
Old Aug 16, 2007 | 11:32 PM
steve40th's Avatar
steve40th
Good deal on the parts. Shipping would have added 30 bucks to hear.
Old Aug 16, 2007 | 11:57 PM
bogus's Avatar
bogus
well... I had them overnighted...
Old Aug 17, 2007 | 01:21 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default engine dies
is there a possibility that your engine ground is determined by your engine mounts?
move the engine either way in a turn, and the engine dies without a proper ground strap?
Old Aug 17, 2007 | 01:37 AM
steve40th's Avatar
steve40th
I have had the starter cable just a tad loose cause the engine to die temporarily.
Old Aug 22, 2007 | 09:53 PM
bogus's Avatar
bogus
status update:
I still don't have a clue, but the loose grounds/starter wires as mentioned above are actually my next step. Unfortunetly, I won't be able to do anything about it until Sunday, at the earliest.
I have replaced the ignition switch and TPS, no change.
It sure is odd... but I am wondering if the motor mounts, at 163k miles have finally given up. I have newer ones, I can and try and swap them out...
Old Aug 23, 2007 | 12:16 AM
  #33
silverman6602's Avatar
silverman6602
i have the same problem with my 89', when i "kick it" around a turn the motor stalls, then as soon as i let off the gas and go straight its fine. it has happened multiple times with all different levels of gas in the tank.... i was thinking it might have somthing to do with the injectors, but im not posivtive i havent gotten around to changing them yet
Old Aug 23, 2007 | 12:23 AM
  #34
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by JrRifleCoach
The turning g's are impacting some wiring? Might try looking for a loose connection, or bad grounding point. Maybe a wire wrapped around the steering shaft?
Cmon Andy. You R&R'd the TPS and ignition switch?
Something is loose forward of the steering wheel.
So does the ALT make the noise continously? Or only when turning?
What are your voltage readings with & without a load?
Old Aug 23, 2007 | 01:04 AM
  #35
jhammons01's Avatar
jhammons01
Make sure that nothing is hitting the top of the Opti or the plug wires. IN other words think about a Cross talk of the Spark plug wires. Or the Coil wires that lead to the Opti. Is there something frayed with those wires??? Is there something that could get to all the plug wires at once.
The reason I ask this is I had a heat shield come loose and lean up against a Distributor cap one time. It only did it when I turned........When I found out what it was....at night time and fooling around with stuff.......it was like a light show with all the blue "lighting" coming off those plug wires at the distributor.......
See if an ignition wire of some sort has some how come in contact with a Header and has the insulation burned off. Now when you corner it leans against something grounded.
That is all I got....
Old Aug 23, 2007 | 02:10 AM
  #36
bogus's Avatar
bogus
I know... I just haven't had time to debug this... it's been hectic... stupid busy...
  #37
bogus's Avatar
bogus
Good idea... except I have the LTCC, which bypasses the opti's high voltage section.
To Stalling... but only on turns... hm...
Old Aug 24, 2007 | 01:26 AM
  #38
bogus's Avatar
bogus
I am going to go to basics... Fuel filter is job one.
Old Aug 24, 2007 | 01:41 AM
  #39
cv67's Avatar
cv67
St. Jude Donor '05
How full was your tank? Im wondering if you r bladder in the tank is all messed up/deformed and around corners your pickup is uncovering
Old Aug 24, 2007 | 01:59 AM
  #40
JrRifleCoach
I'm not sure that would cause the ABS system to go into self-test.......
