McJacks headers
Old Aug 14, 2007 | 09:34 PM
gator79's Avatar
gator79
Default McJacks headers
has anyone used McJacks headers? did they fit well ?
Old Aug 14, 2007 | 10:09 PM
STL94LT1's Avatar
STL94LT1
Never heard of them. Got a link?
Old Aug 14, 2007 | 10:20 PM
gator79's Avatar
gator79
sure do
http://www.vetteheaders.com/servlet/...rvette+Headers
Old Aug 14, 2007 | 10:49 PM
bogus's Avatar
bogus
I know Jack. The headers are not all that bad... are they as good as say, Exotic muscle? I don't think so, but they are mucho cheaper.
Old Aug 14, 2007 | 10:50 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Hmmmmm.....don't know but Hedman Elites are $200 less and we know they fit.
Old Aug 14, 2007 | 10:51 PM
bogus's Avatar
bogus
oh, these will fit. no question about that.
I used to so some work for Jack a couple years ago. Pretty cool guy.
Old Aug 14, 2007 | 11:19 PM
gator79's Avatar
gator79
for long tubes???
Old Aug 14, 2007 | 11:29 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Default McJack's Headers
Just took a look at their site. They look nice, but surely are not anywhere close to being tuned headers, such as Hooker Suoer Comps.
Maybe to some it doesn't matter, but through past experience, tuned is the only way to go, IMHO. Take a look at the length of #2 primary tube compared to #8. No comparison. And Hookers are not that much more expensive. Just my 2 cents worth.
Rich K
Old Aug 14, 2007 | 11:36 PM
gator79's Avatar
gator79
Rich K
I have only seen super comps in shorties, do they make long tubes?
I now E/M, TPIS make long tubes for 93 who else does?
Old Aug 15, 2007 | 01:00 AM
86PACER's Avatar
86PACER
Looks like the passenger side plugs would be a pita to change with those.
Old Aug 15, 2007 | 07:25 AM
Mekanic's Avatar
Mekanic
I just want Hedman to come out with a set of LTs with the LT1/4 style air fittings.... is that too much to ask??
Old Aug 15, 2007 | 08:11 AM
BADDUCK's Avatar
BADDUCK
Originally Posted by gator79
for long tubes???
yes, actually $220 cheaper with 14 ga tubing and 3/8" flange.
Old Aug 15, 2007 | 09:01 AM
The Evil Genius's Avatar
The Evil Genius
From: Dayton, OH HAWG: "this is Off Topic...it can get a bit north of care bears and strawberry shortcake in here"
Don't see anything on their site for an LT car.
Old Aug 15, 2007 | 09:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Those long tubes sure look like my Hedman Elites. Does Hedman build these for Jack.
Old Aug 16, 2007 | 03:09 AM
thirdtimevetteowner
I just posted on a different thread some unsettling news about Hooker SC's, at least to me since they used to be my header of choice. According to a Summit salesman, and comparing along with him in a catalog, the Hooker SC's are 3/4 length primaries, I think 26" as opposed to 30". So will they work as a true dual setup? I think I saw a post where you can get collecter extenders to get them to work, but that would throw the torque curve way off, combined with the short primaries. Someone plz. correct me if I am wrong. I suppose it depends on the heads, intake, cam, and tune. Any help appreciated.
Rich K
Old Aug 16, 2007 | 07:02 AM
gator79's Avatar
gator79
what is the differece between L98 headers and LT1 headers? is it just the air tube fitting? if you were eliminating the air system could you use L98 headers on a LT engine?
Old Aug 16, 2007 | 08:35 AM
The Evil Genius
Excellent question right there, I'm not fully sure. Is it a fitment issue?
To McJacks headers
Old Aug 16, 2007 | 10:40 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
You also have Melrose and Stainless Works to choose from. I think they are all about the same quality and cost.
Old Aug 16, 2007 | 10:45 AM
Speed Hound's Avatar
0Speed Hound
Former Vendor
Melrose headers fit great and for the rest of the system you can get the Random Technology dual exhaust.
The only difference between L98/LT1/4 headers from Melrose is the AIR fittings. I believe that is also true for TPiS and Hooker, but I can not say say that without a doubt.
Old Aug 16, 2007 | 10:56 AM
LouisvilleLT4's Avatar
LouisvilleLT4
The short answer is yes. For example the Hooker 2151 super comp longtubes that everyone loves to install were designed for the L98 but can be made to fit an LT1, or in my case an LT4. Here are the changes I had to make to make them work:
-Grind a little bump off of the frame that hit one of the primaries. No biggie.
-Grind about 1 mm off the edge of the motor mounts, and reverse the motor mount bolts so the primaries do not hit.
-Stretch by hand the brake lines coming out of the master cylinder until they were out of the way of one of the primaries.
-Eliminate the AIR system and cats. (I don't have EGR, since it's an LT4)
-Pay an exhaust shop $50 to block off the O2 bung on one of the primaries, and put two more O2 bungs farther down on the collectors.
-Eliminate the stock spark plug wire holders, use wire ties and plug wire separators instead.
-Eliminate the alternator brace and instead secure the alternator to the accessory brace with a bolt and some washers.
-Re-use two of the stock exhaust manifold bolts (the ones with studs on the end) so that you can keep your A/C brace and your oil dipstick. To reuse stock bolts you must use spacers between the bolt and the header, but luckily the proper spacers were included with the headers.
-Grind a very small amount off the analog ECT sensor to allow the headers to be fed in from the bottom.
-Purchase an O2 sensor wire to extend the driver's side O2 sensor wire.
-Pay an exhaust shop another $150 to cut off the ends of your stock exhaust, and then weld flanged expanders on so that it mates with the headers.
-You no longer have bungs for the rear O2 sensors, so you must now wire up an O2 simulator to trick the computer into thinking there are still cats. If you do not, fuel trim will be adjusted slightly by the computer to try to get the cats working better, according to the FSM.
