heater not getting hot
Old Aug 15, 2007 | 07:41 PM
llesg's Avatar
llesg
Default heater not getting hot
I have a 94 and the heater is not blowing hot.It seems to have been getting weaker and weaker over time but after draining the radiator and refilling it it seems to be weaker than ever!! Clues??
Old Aug 15, 2007 | 07:49 PM
jghmczo6's Avatar
jghmczo6
You may not have coolant in the heater core, start the car let it warm up the put the heat on and let it run, should only take a minute to begin heating. If not you may have a bad heater core, is there liquid on the floor panel? Mine is a '90 so I am not well versed on '94's.
Hope this helps
Old Aug 15, 2007 | 07:50 PM
Corn Flakes's Avatar
Corn Flakes
Hope this helps
on the heater core. Also, what thermostat are you running. If it is a 160* thermostat, then your car may not be getting hot enough.
Old Aug 15, 2007 | 07:56 PM
llesg's Avatar
llesg
Not getting any water inside,The car usually runs at around 226 degrees
Old Aug 15, 2007 | 08:02 PM
SunCr's Avatar
SunCr
May be plugged up - but first verify that the temp door moves. Remove the Blower Module on the left hand side of the Evaporator Case and look inside. The door should move while someone changes the controls from 60 to 90. If the door works (if it doesn't repost), pull the heater hoses off of the core and flush it out - make sure the hoses are clean too - believe for your Year there's a restriction or check valve from the tank to the core. Clean it. If flushing doesn't bring back the heat and the door works, you need a new core.
Old Aug 15, 2007 | 10:31 PM
Lichen's Avatar
Lichen
Why in the world are you running the heater this time of year?
Old Aug 15, 2007 | 10:36 PM
89 Bob L's Avatar
89 Bob L
I aagree with SunCr. Could be a door issue or a clog.
Old Aug 15, 2007 | 10:50 PM
aminnich's Avatar
aminnich
Safe to assume you bled the air out each time using the bleeder screws? Are both hoses getting hot? 102*F here today, my heater damn well better NOT work!
Old Aug 15, 2007 | 11:40 PM
enventr's Avatar
enventr
IMO it seems a little too hot for cruising temps- should be 196-201 dg.Use the digital gauge not the analog
Old Aug 16, 2007 | 12:55 AM
llesg's Avatar
llesg
Thanks everyone for the input, I found the restrctor in the hose and imediately snapped it in half.......guess I needed a new one. Replaced it with a 1/2 inch piece of copper pipe for now.Refilled with water and checked the heater. I did'nt know about the bleeders!. Anyway it blows 130 out the upper vents and 115 when I put it on auto 90 . I also noticed that there is virtually no air blowing out on the passenger side!?!? So I have heat and another little mystery!! Thanks again everyone!!
Old Aug 16, 2007 | 01:11 AM
rolando4812's Avatar
rolando4812
Old Aug 16, 2007 | 03:28 PM
llesg's Avatar
llesg
Originally Posted by rolando4812
As for runnig the heater this time of year,The tempeture gets in the high 50s at night and I like driving with the top DOWN! Theres nothing like driving under the stars at night. Maybe I just waited to long in my life to get a convertible!!!
Old Aug 16, 2007 | 05:06 PM
aminnich's Avatar
aminnich
You in Alaska or Siberia? Replace that restrictor ASAP to keep from damaging your heater core with excessive pressure at higher RPMs.
Old Aug 16, 2007 | 05:59 PM
InHot's Avatar
InHot
It's there for a reason. Just keep your foot out of it till you replace it!
Old Aug 16, 2007 | 06:20 PM
JEFNLSA's Avatar
JEFNLSA
I've gotta admit that in the 3+ yrs that I've owned my LT4, I've never ever used the heater. Welcome to Phx AZ. Heck, in the winter here you still use the a/c.
Old Aug 17, 2007 | 02:54 AM
llesg's Avatar
llesg
Thanks for the advice I will get another ASAP. I live in sunny california but it still gets cool at night!!
Old Aug 17, 2007 | 09:52 AM
jimmers's Avatar
jimmers
Thats enough out of you!
To heater not getting hot
Old Aug 17, 2007 | 10:02 AM
Darkgh0st's Avatar
Darkgh0st
Did you know that replacing the heater core is one of the most fun and exciting projects you can do with your corvette??
Old Aug 17, 2007 | 11:41 AM
NEVRL8T's Avatar
NEVRL8T
Yep. The first step is to do exactly whats in your avatar. Put a gun to your head.
Old Aug 31, 2007 | 01:59 AM
samsonb's Avatar
samsonb
I just got an 89 Vette. The defrost only blows cold air. I get A/C. When I turn it up closer to 90, the thing quits blowing air. Does this sound like that door you guys are talking about?
Sorry, but I'm new to this tech stuff.
