heater not getting hot
Old Aug 31, 2007 | 02:51 AM
SpinSirLT4's Avatar
SpinSirLT4
Originally Posted by JEFNLSA
I've gotta admit that in the 3+ yrs that I've owned my LT4, I've never ever used the heater. Welcome to Phx AZ. Heck, in the winter here you still use the a/c.
I agree, Ive had my current LT4 for going on 4 years now and Ive never once run the heat. The coldest month of the year here in Jacksonville, FL is usually January and AT THE MOST, Im riding around with the windows down and A/C off but never the heat on. However, Ive been through two A/C control modules and the current one is going out, thank goodness I ordered an extra the last time around! As horrible as it sounds to ride around without heat in 50 degree weather, no A/C in a blistering 100 degress will really put a damper on your day!
Old Aug 31, 2007 | 08:38 AM
conv90's Avatar
conv90
Originally Posted by llesg
I have a 94 and the heater is not blowing hot.It seems to have been getting weaker and weaker over time but after draining the radiator and refilling it it seems to be weaker than ever!! Clues??
How about the level of the coolant?
Dropped?
If yes, and you are experiencing high coolant temps, i suspect the head gakets.
-Beppe-
Old Aug 31, 2007 | 09:41 AM
canoeman's Avatar
canoeman
Originally Posted by aminnich
Safe to assume you bled the air out each time using the bleeder screws? Are both hoses getting hot? 102*F here today, my heater damn well better NOT work!
And where would these be?
