P0161 Code
Old Aug 16, 2007 | 02:28 AM
Shylor's Avatar
Shylor
Default P0161 Code
Had an engine service light on a 1996 Corvette coupe, it showed a P0161 code via a Scangauge2. According to my service manual this is a heater circuit code. I reset the warning light and it has not come back on. Not sure what caused it to display the engine service light, so I am wondering if I should be worried? I appreciate any help.
Old Aug 22, 2007 | 03:00 AM
Shylor's Avatar
Shylor
Not one person has an answer for me?
Old Aug 29, 2007 | 05:54 PM
Shylor's Avatar
Shylor
Can someone at least tell me where to go to find out what this code does?
Old Aug 29, 2007 | 06:02 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Use the Search function, Advanced, Archive posts... you'll prob find your answer....
Old Aug 29, 2007 | 06:09 PM
ultraviolet70's Avatar
ultraviolet70
It concerns the internal heater in the O2 sensor Bank 2 Sensor 2 (right exhaust bank rear sensor-behind cat. conv.).
Will it set it again? Most likely. It's an easy fix, when it does replace the sensor and clear the code.
Old Aug 30, 2007 | 01:01 AM
Shylor's Avatar
Shylor
ultraviolet70,
Thanks for the answer. I think I will wait and see if it throws the code again before replacing the sensor. Who knows maybe it won't. Just for information, what does this internal heater do for the 02 sensor?
vinnies87,
Just so you know I did do a search and is the reason I posted here, because I could not find the answer using the search function.
Old Aug 30, 2007 | 01:03 AM
96GS#007's Avatar
96GS#007
Originally Posted by Shylor
ultraviolet70,
Brings it up to operating temp quicker.
Old Aug 30, 2007 | 01:38 AM
Shylor's Avatar
Shylor
And why is that needed?
To P0161 Code
