big oil leak!
Old Aug 16, 2007 | 08:33 PM
all show and more go's Avatar
Default big oil leak!
ive posted about this before but am now getting to work on it tonight,where is the most common oil leak to happen in the front of the motor,there's oil all over the idler pulley,so i think it could be the timing chain gasket,i need help!
Old Aug 16, 2007 | 09:06 PM
someones gotta know something!
Old Aug 16, 2007 | 10:14 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
OK - I am in the middle of the "oil sieve" syndrome repair. Mine also had an oil leak that progressively got worse until I noticed larger and larger spots of oil. The underside of the front of the motor, oil pan, and behind was pretty much covered.
I haven't identified any specific leak location, but it seems it was leaking from the water pump shaft seal, the timing cover gasket, oil pan gasket and probably the intake gasket as well. The car has ~150k miles and needs a little TLC.
I know you don't want to hear this, but it is probably a combination of the intake manifold and the timing cover. Intake gasket won't be a major problem, but the timing cover gasket can be a major undertaking if you are not the wrenching type. I think the Chevy dealership would charge at least $1500 for this job, and wouldn't spend the time cleaning everything up that I am doing along the way.
Good Luck - Feel free to ask questions, as I am well into this job, and just doing a little bit every night or two. Tonight I finally got to the oil pan and it is down, awaiting to remove the timing cover tomorrow.
Cheers
Old Aug 17, 2007 | 12:16 AM
Cheers
1500 bucks is nuts ive already removed everything(accesories) 2marrow ima start to change the gasket,i dont have any issues with the coolant(yet) i just have to get he gaskets and the oil(prob royal purple)!
Old Aug 17, 2007 | 01:28 AM
engle1147's Avatar
engle1147
Default Sythetic or Not?
My car leaks oil but that's how I know I still have oil in there.....if it stops leaking I'll begin to worry about it.
From my experience large leaks usually occur from the crank seals -- look at the rear main seal or the timing cover crank seal. These types of leaks are very common. A little oil can go a long way. It might not hurt to do a compression test to ensure that's not a "blow by" gremlin in there. If you have a compression "blow by" problem new seals won't help for long.
Let me ask you this....have you switched over to sythenic motor oil?
If you've noticed that your car is leaking more oil than usual since the switch then that's your problem: "ultra thin synthetic motor oil". Synthetic oils can make loose seals leak ~ if you insist on using sythetics use a heavier wieght to slow the leaks down a bit.
Earlier model engine seals were not designed to stand up to sythetic oils. If you entend on using synthic oil get an approved seal intended for that use.
Good luck!
Old Aug 17, 2007 | 10:34 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can by a U/V light leak detection kit at most auto parts stores. That'll help you positively ID the leaks.
Old Aug 17, 2007 | 11:16 AM
i wish i would have known before,i already thave the timing cover off,dont know if its the seal,doesnt seem to look damaged,man i start school 2marow and need to drive this car 2 hours away hopefully i'll be able to throw things back together in time,i feel like im on one of those tv shows where they have a deadline!
Old Aug 17, 2007 | 08:51 PM
Greg Gore's Avatar
Greg Gore
Most likely cause is the RTV sealant applied between both ends of the intake manifold and the block china rails. Whatever RTV they originally used deteriorates with age and loses its ability to seal and has to be replaced. Second likely cause is the crankshaft hub seal or the waterpump driveshaft seal. If the car has around 100K miles it is likely these parts have wear grooves which will need to be addressed in addition to installing new seals. Another likely cause for LT-1 oil leaks is the Oil filter adapter "O" ring. It takes a set and hardens and leaks. My 96 project car leaked so bad from all these areas at the time I got it that oil was dripping off the mufflers and rear end housing. I have posted in other threads about that.
Old Aug 18, 2007 | 12:00 AM
ubnpast's Avatar
ubnpast
possibly the crank seal?
Old Aug 18, 2007 | 02:46 AM
just finished it at 2 am,deadline accomlished,i didnt really find the leak! oh well at least its done!
Old Aug 18, 2007 | 05:06 AM
enventr's Avatar
enventr
if you do this seal replace the hub-ask me how I know-done 3 times
(They have a groove worn into the hub from milage)
Old Aug 18, 2007 | 11:25 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default hub groove
they sell a hub groove cover that is stainless steel that you tap onto the harmonic balancer hub. it replaces the worn area, and makes the seal tighter and lasts longer. you just have to lube it when you install it, or it will overheat the seal, and may leak prematurely.
Old Aug 18, 2007 | 05:38 PM
enventr's Avatar
enventr
Tried that first and did not work-new hub worked perfect
To big oil leak!
