94 Blower motor question
Old Aug 19, 2007 | 09:20 PM
grayml's Avatar
grayml
Default 94 Blower motor question
Hello all,
The AC/Heater blower motor only runs in the low speed range in my 94, the vent doors are operating correctly and I have replaced both relays.
When I switch the AC between closed & open to outside air setting there is no difference in the fan speeds.
Any ideas?
Old Aug 19, 2007 | 09:37 PM
SunCr's Avatar
SunCr
Fan speed is controlled by a Module bolted to the left side of the Evaporator Case. It gets low voltage signals and amplifies them to control blower speed. That input is usually a Brown or Tan wire and it should have 2.5 volts at 1; 6 volts at 10. Output is Purple or whatever is hot at the Blower. 1 should produce 4 volts, 10 12 volts. If it has the input but the output doesn't change, replace the Module (which is all most always the problem). If it doesn't have the inputs, either your Controls aren't sending them to the Programmer (the Processor which then relays them to the Module) or the Programmer isn't working. Use a bi-directional scanner through the CCM link to find out which one.
