1991 L98 TPI to Carb?
Received 1,427 Likes
Yes, it can be done.
I see no benefit to doing so unless you have a particular reasoning behind it for us?
To answer the question, yes it can be done. Off the top of my head you would need an intake, carb, fuel pressure regulator, distributer, (HEI w/vac advance).
You will need to wire up your fuel pump to come on with ignition, and use the regulator to bring the pressure down, (5-7 psi). May need some other things depending on the tranny.
I would do a search since all of the info is out there. You also would not be subject to all the "old technology - why would you do that" responses.
Imtrumpeter
Imtrumpeter
Received 3,043 Likes
St. Jude Donor '05
UNless there is a real good reason to it would probably cost you less to fix whatever FI problem (Im assuming this is why) you are having.
