find code with a paperclip
Old Aug 20, 2007 | 05:50 PM
dpsantoli's Avatar
dpsantoli
Default find code with a paperclip
i have an 87 vette and the service engine soon light is on. the car runs horrible when first started and as it warms up it runs perfect. i would like to know how to check for the trouble code using a paperclip. i did a search and couldn't find it. thanks pat
Old Aug 20, 2007 | 07:02 PM
dpsantoli's Avatar
dpsantoli
i conducted the paperclip test and got the 12 code and the 14 code (coolant temp sensor circuit) and my research continues. pat
Old Aug 21, 2007 | 09:42 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2014.pdf
Old Aug 21, 2007 | 10:21 AM
Sam Lam's Avatar
Sam Lam
The paper clip method is easy....once you get the wire bent just right. If you want a better method, go to Auto Zone and ask for a FREE code key that looks like this:
Just insert the key into A&B holes and you are set to go. Place the key in a location where you can find it for the next use......or go get another free key
Old Aug 21, 2007 | 07:35 PM
AGENT 86's Avatar
AGENT 86
WTB one Autozone code key
Looks cooler than my paper clip
Old Aug 24, 2007 | 08:55 PM
dpsantoli's Avatar
dpsantoli
i replaced the temp cooling sensor and the car runs great. the best part about it was the sensor was 11.99 at autozone. nothing better than a cheap fix. thanks to all. pat
Old Aug 27, 2007 | 09:37 AM
Da Mail Man's Avatar
Da Mail Man
......they still have these?...i thought that these were a long time past....
Old Aug 27, 2007 | 12:18 PM
JonnyAngle's Avatar
JonnyAngle
the A and B holes are the two holes on the far left? The A on the top row and B on the bottom row? 1986.
Edit: Figured it out
To find code with a paperclip
