Mods......should I re think....
http://forums.corvetteforum.com/show...1786796&page=2
I purchased the Super Ram, I purchased 1.6 rockers, springs, ect... based on forum advice.
Now, I really don't mind doing the work, but am I going to wind up like the OP of the thread? I'd like to end up with a car who's power band is similar to stock (which is shy I'm keeping the cam) but just more of it.
After I do the intake and rockers, LT headers are next, with dual high flow cats.
With the Super Ram and LTs am I giving up a lot of torque.
I already have a "high performance" chip, which I will have tuned specifically to the mods when done.
Thanks for tolerating my paranoia......
FWIW, My setup has an almost stock powerband - TPIS big mouth with runners and ported plenum, iirc AFR 180 heads, TPIS 288 cam, TPIS long tubes, Borla /w dynomax mufflers. Supposedly around 350hp/420tq, looks almost stock, smogs fine, and runs 12's.
I don't want to get into a state of paralysis by analysis.
The SR seems to be more suited to low-mid RPM ranges than does the MR. That's why I went that way.
I know a cam would do wonders, however, I am not about to do all that work. I am going to install the SR and rockers, run it, then do the LTs this winter or in the spring. I can only spend so much money at one time. I have a boat too, the wife starts to b*tch...
Followed by a torque converter and shift kit.
I recognize that my weakest spots will be the heads and cam. But that's a lot of money and work. I've done it before on other vettes (C3s I've had) and it's a bitch. Serious.
I'd rather ask the questions now, then have to do it over later.
What I may consider instead, which is actually MORE expensive, would be some forced air. Perhaps a Vortex or Procharger. That would bring the torque back.
I want to get this other stuff done first, as long as I'm not making it WORSE.
The car runs like a top as it is. Just tuned it up and got it tuned by Corvettes of Westchester.
Sounds like you know what you want
vader is right.....you'll need the chip re-calibrated, and if i were you i'd wait until you can everything at once.
From what I understand, the L98 responds well to intake and exhaust.....I was just going to throw the rockers in since it's easy while I'm there.
I also understand that the Torque converter and shift kit will also help.
That's about as far as I can go before I get to the "big stuff".
I know the heads would be a peice of cake with the intake off, however, that's another $2k I can't spend right now. Like I said, boat+wife=less mods.
SO, do you guys think I'm going about this in a sensible manner. If it's an all or nothing, I have to do nothing....
Whatta ya think?
But dont be upset when things dont magically improve like the poster in that thread.
Whatta ya think?
and tell her i said it, right here
I hate doing cams, in the car. And I'm not about to pull the motor.
I figure at some point the heads will have to come off resulting from a blown head gasket or something, THEN I'll do the cam....
