Cruse Control Issues
Old Aug 20, 2007 | 08:44 PM
indmfgsol nick's Avatar
indmfgsol nick
1st Gear
Default Cruse Control Issues
I bought my '84 Vette about 6 weeks ago and I really love it. It was at a nice price and I love the power. I do have a problem with the Cruse Conrol. 3 years earlier the previous owner put a new battery in. When doing so they had to remove the Cruse Control unit from the frame to get the battery out. I checked the fuse and it was good. Does anyone know how the linkage should be adjusted under the boot? Currently it is quite slack on the chain dangles. Any recommendations would be greatly received.
Thanks!
Old Aug 20, 2007 | 09:41 PM
86PACER's Avatar
86PACER
http://www.corvettefever.com/howto/82001/
Old Aug 21, 2007 | 08:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Cruise%20Control.pdf
Old Aug 21, 2007 | 03:21 PM
kehler's Avatar
kehler
Removed the cruise to install the battery? They're at two different ends of the car
Old Aug 21, 2007 | 03:24 PM
86PACER's Avatar
86PACER
Check the two vacuum lines below the servo. One is big, one is small. As are the fittings they go over so that you can't mix them up.
Old Aug 22, 2007 | 12:32 AM
John Arthur's Avatar
John Arthur
Default remove battary
lot easyer to remove the screw's in the finder well and one by the door pull down and slide out the battary!
To Cruse Control Issues
