Alcohol Injection or there bouts
Old Nov 6, 2001 | 05:06 PM
Arisa's Avatar
Arisa
Default Alcohol Injection or there bouts
Would it hurt a stock motor if it all the sudden swallowed a lot of alcohol by accident ??? I don't care if it makes more power just so long as it would'nt hurt anything.
Toying with ideas!
Neal
Old Nov 6, 2001 | 09:04 PM
bogus's Avatar
bogus
Default Re: Alcohol Injection or there bouts (Arisa)
It won't hurt to run booze... but it won't help...
the only thing that will work with alcohol is higher compression.
you don't wanna run too much alcohol, tho... there are problems here that you need to consider... the biggest, alcohol will harm the rubber and metal components of the engine... CART and IRL, and I suspect WOO, and anyone who runs alcohol engines, pickle them in gas after they run the alcohol. or else things start to rot.
Old Nov 6, 2001 | 09:34 PM
WG87's Avatar
WG87
might you be thinking alcohol+nitrous inj.? :D
otherwise not sure on low comp motor, but on race motor
basicly just fuel sys. rubber and volume,nearly 2x gas.
oh and foam out of fuel cell
Wayne
:cheers:
Old Nov 7, 2001 | 12:11 AM
AS84's Avatar
AS84
Default Re: Alcohol Injection or there bouts (WG87)
I don't believe you can just run some alocohol through your car. I know that you cannot do it on a carb setup. I had to switch carbs and pumps as well as a larger fuel line on my race car when I converted...but then again its a carb setup. Wouldn't it burn the heck out of the valves?
Old Nov 7, 2001 | 10:31 AM
Arisa's Avatar
Arisa
Default Re: Alcohol Injection or there bouts (AS84)
WG87, Not even close, but good try
These are the things I need to know about. It wouldn't be all the time, ONLY if another component failed releasing the alcohol into the engine. I just need to know what things could happen if say 1/2 gallon or so "decided" to free itself into the engine. I could care less if it stalled the car, what I don't want is "teardown" problems. IE burn valves, broken crank, etc...........
Thanks so far guys
Neal
Old Nov 7, 2001 | 07:15 PM
AS84's Avatar
AS84
Are you wanting to use alcohol as an octane booster?
[Modified by AS84, 5:17 PM 11/7/2001]
Old Nov 8, 2001 | 09:00 AM
Arisa's Avatar
Arisa
In it's everyday use the alcohol won't be going through the engine, however if the system it will be running in ruptures then it could (depending on the rupture location) deliver itself to the engine for consumption.
Neal
Old Nov 8, 2001 | 05:33 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Are you planning to use alcohol as the contents of a heat exchanger for your fuel system? Like a "cool can" type of device? What's the story?
Cory
Old Nov 8, 2001 | 07:42 PM
WG87's Avatar
WG87
ok, I won't even try another guess,but 1/2 gal. of any fluid
into the intake tract and you will probably at least bend rods
and possibly break the crank
Wayne
:seeya
Old Nov 9, 2001 | 05:06 AM
ChrisB's Avatar
ChrisB
In the situation you describe as long as you don't hydro-lock the engine then you will be okay.
Old Nov 9, 2001 | 09:45 AM
Arisa's Avatar
Arisa
WG87,
I hope I didn't upset you with my comment.
I have learned to keep a pretty tight lid on some of my ideas because I end up getting a whole lot of these :nono: :confused: :lol: :crazy: If you know what I mean. The only way *we* can learn is through expermentation so I experment. I am sure someone else has probably tried what I am thinking about & it didn't do diddley, but that's how I have fun. I just love to tinker. I hope you understand.
Neal
Old Nov 9, 2001 | 04:13 PM
GRX's Avatar
GRX
Is it methanol (wood alcohol) that you want to experiment with?
Old Nov 9, 2001 | 04:14 PM
WG87's Avatar
WG87
WG87,
Neal
Neal,
not at all, I really was just out of guesses!
:cheers:
Wayne
Old Nov 9, 2001 | 04:34 PM
Arisa's Avatar
Arisa
Default Re: Alcohol Injection or there bouts (GRX)
Rough math say it needs to be close to 95% pure denatured alcohol to handle the temps I am going to subject it to. I don't know off the top of my head if they are the same.
Neal
Old Nov 9, 2001 | 04:44 PM
Larrym96815's Avatar
Larrym96815
Old timer talk again :cool: I had a friend many years ago that had a 58 Chevy, 348, tripower. He used a tank, pump, and hose for a windshield washer. He routed the hose into the air intake. When he wanted a shot of alcohol from the windshield washer tank he just bumped the switch. Did it help? Did it hurt? Was it cool to talk about? You bet! :cool:
Aloha,
Larry
Old Nov 9, 2001 | 04:59 PM
Arisa's Avatar
Arisa
Default Re: Alcohol Injection or there bouts (Larry Mackey)
He used a normal windshield washer pump................hummmmmmmmm......... .........that may solve my circulation problem............cheaply..........
Neal
To Alcohol Injection or there bouts
