Anyone know what code 32 is?
Welcome to C4 vette codes it is very ....
First locate your car's ALCL
this component is located just below the instrument panel and
to the left of the center console. Remove the plastic cover
the first two slots to your right are the A & B slots for a drawing of
the alcl module's picture is added below.
The A slot is the diagnostic slot and the B slot is the ground
slot. insert the computer key(jumper wire) into these slots (with the engine
off) this is very important...now only put the ignition key
to on ( not start !!!) the check engine light will display a
code 12 which is one flash followed by two flashes.
this code will be flashed three times ..followed by the
trouble code stored in your car's computer.
what ever the code is it will be flashed three times.
have a paper and pencil ready and write down the
code .
code 13 =>oxygen sensor
code 14 =>coolant sensor
code 15 =>coolant sensor
code 21 =>throttle position sensor
code 22 => throttle position sensor
code 23 => manifold air temp sensor
code 24 => vehicle speed sensor
code 25 => manifold air temp sensor
code 32 =>egr system
code 33 =>map sensor
code 34 =>maf sensor
code 35 => idle air control
code 41 => cylinder select error
code 42 => electronic spark control
code 43 => electronic spark control
code 44 => lean exhaust
code 45 => rich exhaust
code 51 => PROM
code 52 => fuel calpak
code 53 => system over voltage
code 54 => fuel pump circuit
code 55 => ecm
code 62 => oil temp
As for your problem, it sounds like you have some bad fuel injectors. Are they the orginal Mutlitechs?
