Whats my problem?
Old Aug 29, 2007 | 05:52 PM
rolando4812's Avatar
rolando4812
Default Whats my problem?
There is a noise coming from the serpetine belt. but idk if its the belt or the wheels that are the problem. how do i find out? thanks
Old Aug 29, 2007 | 06:07 PM
Curveit's Avatar
Curveit
Probably the idler pully. You can use a yard stick or something; put it to your ear, and CAREFULLY probe stationary areas of suspect items. With the motor running of course. It will amplify any noises.
Old Aug 29, 2007 | 06:43 PM
AKS Racing's Avatar
AKS Racing
Typically idler or alternator.
Old Aug 29, 2007 | 06:57 PM
rolando4812
it a high pitched noise. sounds like scratching a record. i'll try that
Old Aug 29, 2007 | 08:22 PM
Canam's Avatar
Canam
or a really high pitched whistle. Its your idler pulley. 40 bucks. I just changed mine.
Have it checked first with a mechanics stethoscope.
Old Aug 29, 2007 | 09:30 PM
rolando4812
yea i want to get that checked
Old Aug 29, 2007 | 09:56 PM
rolando4812
can it still be the idler puller if the noise is still there while i'm driving. the noise is there at idle and when in drive
Old Aug 29, 2007 | 10:40 PM
AKS Racing's Avatar
AKS Racing
Absolutely. The idler pulley has nothing to do with the car being at an idle. It is a pulley that helps to route the serpentine belt amoungst the various accesories. If bad, it would make noise at idle, in drive, or while cruising down the road.
Aaron
Old Aug 29, 2007 | 10:44 PM
rolando4812
oh wow. how much will a good one run me? can i get one at a local parts store?
Old Aug 30, 2007 | 07:47 PM
rolando4812
i drove the car today. the noise was there in the morning but wasn't there when i drove home. i tried this a few minutes ago and put the stick on areas of suspect, they all made a different sound. what should i be looking for?
Old Aug 30, 2007 | 08:13 PM
JOESROAD's Avatar
JOESROAD
Could be the smog pump, replaced mine after the same type of noise and its gone.
Old Aug 31, 2007 | 02:47 AM
Curveit's Avatar
Curveit
The one you're concerned with ... It should be apparent; as you said, they all sound different
Old Aug 31, 2007 | 09:32 AM
engle1147's Avatar
engle1147
My smog pump crapped out and make a weird noise around the belt area. I've also have had the bearings go bad on the tensioner idler pulley. You can buy just the idler tension pulley (with new bearings) from NAPA for around $20. The pulley is cheaper than the smog pump....a good place to start. Put a new "S" belt on the car is your unsure of how many miles are on it.
Old Aug 31, 2007 | 01:20 PM
Da Mail Man's Avatar
Da Mail Man
.....if you are not sure exactly where the noise is coming from, remove the belt and start the car briefly...once you can determine that it is coming from the engine compartment, reaffix the belt......i had a similar noise on my 88 and i removed the idler pulley and replaced the BEARING and reinstalled it all in 20min.....if your belt appears to be worn (cracked at edges or rows worn) replace that.....any rotating mass can be the source.....
Old Aug 31, 2007 | 01:23 PM
Lichen's Avatar
Lichen
Mine was the steering pump pulley, but you could actually see it wobbling all over the place.
Old Aug 31, 2007 | 07:07 PM
Yellow2015's Avatar
Yellow2015
To Whats my problem?
