Stock Compression Ratio L98??
Aug 30, 2007 | 02:13 PM
I have searched but found nothing definitive. I need to know the compression ration of a BONE STOCK 1989 L98 out of an 89 vette. Thanks
Aug 30, 2007 | 02:21 PM
9.5:1
Aug 30, 2007 | 02:27 PM
what is the crappiest possible gas I can run without fear of detonation?
Aug 30, 2007 | 03:14 PM
From: One day you're a Comet...the next day you're dust... Arkansas
89 octane will probably work. owners manual calls for 91.
Aug 30, 2007 | 03:20 PM
Cruise-In V Veteran
Where's the poll? I want to vote for something different!
Aug 30, 2007 | 03:34 PM
For 9.5 it should be ok on the lowest, but no higher than midgrade should be necessary.
Only way to be sure is to hook up a scanner and run it and see.
Aug 30, 2007 | 03:36 PM
Quote:
Originally Posted by
kowalski340
85?
Probably not, at least 87. Unless youre at high elevation.
Here we only get as low as 87.
Aug 30, 2007 | 03:42 PM
I would make sure the initial timing is set at the factory 6*, may be able to get away with 85 octane by bumping back to 4*, but I wouldn't do it. I am pretty sure 6* timing and 87 octane will work just fine.
Aug 30, 2007 | 03:46 PM
OOH, you said "crappiest" gas. That has nothing to do with octane. Crappiest gas is Citgo.
Go ahead, start a poll someone!!!
I'll get hammered for this one
Aug 30, 2007 | 04:03 PM
Haha well I meant octane rating if I was really talking about crappy gas I would have said Pemex!!!
Aug 30, 2007 | 05:27 PM
