extending oxygen sensor wire
Old Aug 28, 2007 | 01:18 AM
gator79's Avatar
gator79
Default extending oxygen sensor wire
I am putting my sensors in the collector of my long tube headers is there any special wire to use to extend them? they are on a 93 with non heated single wire sensors
Old Aug 28, 2007 | 01:30 AM
RRT vette's Avatar
RRT vette
You might want to get the three wire heated O2 sensors with the long tubes due to open loop idling. I have a spare engine wiring harness from a salvage yard, that I use if I need extra wires. I suppose a 14-16 ga. wire will work. Just make sure the connection used is real good. Twist, solder, heat shrink.
Old Aug 28, 2007 | 02:22 AM
BAM92's Avatar
BAM92
Even in our warm climate you will find you car going open loop at idle. 3 wire is the way to go.
Old Aug 28, 2007 | 07:11 AM
gator79's Avatar
gator79
why would longtubes make it go into open loop at idle? seems like the exhaust temps should be the same as manifolds, unless it is because the cast manifold holds more heat. what is a good source for heated sensors?
Old Aug 28, 2007 | 07:56 AM
mseven's Avatar
mseven
They just usually won't get hot enough to go into closed loop (or stay in closed loop), especially w/ceramic coated headers. Have bungs welded at approximately a 9 o'clock postion so they won't collect moisture and still be able to be removed. I have used bosch and delco's w/out problems.
Old Aug 28, 2007 | 08:05 AM
gator79's Avatar
gator79
any particular part number? where did you get your power source?
Old Aug 28, 2007 | 08:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Bosch 13190, Autozone
Old Aug 28, 2007 | 08:19 AM
mseven's Avatar
mseven
Any source of switched power will be fine, I believe I used the AIR for power since it is no longer on the car. The sensor draws very lttle amps and you only want it to see power w/key "on".
The bosch number I have here is 13077. I used this one because I already had a 3 wire weather pack (pig tail)for the other side. If I remember there were a couple of places that sold it as a kit (pig tail and sensor), just been awile so I don't recall who it was, but I remember it being around 70.ish (sensor alone is about 48.)
Old Aug 30, 2007 | 02:14 PM
gator79's Avatar
gator79
got those today
do you just ground the other side of the heater circut? or do you use some type of controller/ relay? on an oem system both heater wires go back to the ecm. has anyone had a problem leving 12 volts applied at all times while running? seems like it would be hard on the heater
Old Aug 30, 2007 | 02:29 PM
RRT vette's Avatar
RRT vette
The ECM wire connect the same as the original O2. The 12v wire will need to be spliced into a switched 12v source. There are a few different spots this can be done. I also used a 10 amp fuse inline, though I don't think is needed. You don't want to splice into a always 12v wire....it will run the battery down for one. The ground wire need to be grounded, usually within 1 ft of the O2.
Make sure to test these wires after your finished, with a VOM. You want know if it's working other than the Field Service Mode or by scanner.
Old Aug 30, 2007 | 05:28 PM
JAKE's Avatar
JAKE
On the switched 12V source: I once installed a heated 02 on my 86 and picked up the switched 12V source using the windshield wiper harness.
I found that when the wipers were operating in intermittent mode, the voltage from that source dropped, lessening 12V to the 02, so the 02, again, dropped out of Closed Loop at idle. I found this by monitoring Diacom.
I swapped the 12V source connection to one of the relay wires (forgot which one it serves) mounted on the driver's side inner fender and all was well again.
Bottom line: I'd stay away from choosing the windshield wiper harness as a switched 12V source.
Hope this helps.
Jake
To extending oxygen sensor wire
