84 Just wont quit!
Old Aug 30, 2007 | 05:50 PM
fijidan's Avatar
fijidan
Default 84 Just wont quit!
well, it runs great but continues to run a second or two after i have turned off the ignition and removed the key!
It does have the original cross fire injection and the VATS system has been completely wired around (by someone else).
If you have any experience or advice on cross fire injection i would love to hear from you!
Thanks for your time,
Dan
Old Aug 30, 2007 | 08:28 PM
CFI-EFI's Avatar
CFI-EFI
Someone added a VATS system and then someone else wired around it??? Get yourself a FSM and then using the whole car wiring schematic, get it back the way it belongs.
RACE ON!!!
Old Aug 30, 2007 | 09:00 PM
Chatman's Avatar
Chatman
I have the same problem with my wife. Let me know what you find to be the solution.
Old Aug 30, 2007 | 09:02 PM
champs65's Avatar
champs65
84's and 85's did not have VATS from the factory. It came along in 86, and used a resistance pellet in the key to prevent starting with the wrong key (or otherwise).
Are you referring to the "security" system on your 84? It used a standard key, and had an interlock system with the door locks and a plunger switch mounted on the back inside of the door. It will activate the horn when the system is armed. I don't think that this system will have anything at all to do with the car continuing to run, even if the security harness was "improved" by Bubba somewhere along the line.
I agree with CFI that you should get the wiring right, regardless of the running on issue. One thing that turned me on about my 85 is that there hasn't been a wire cut into anywhere on the car. Sure makes life a lot easier not having to wonder and scratch your head guessing at how things are supposed to work.
Old Aug 30, 2007 | 09:46 PM
fijidan's Avatar
fijidan
I didn't know about VATS starting in 86, I have an original copy of the chevy dealers 84 vette manual-- it has all the schematics (im working on the electronics)
I tried cleaning the fuel injectors, I made sure there were no air leaks and now that electronic trouble is out, I just don't know where to go from here.. any ideas??
Old Aug 31, 2007 | 07:01 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default run on
i added a cooling fan in front of the radiator, and added the power wire to the terminal behind the battery. when I turn off the car, and get out, the fan runs like 15 seconds, then shuts off.
I always figured it was the mas air power/burnoff power that I had tapped into. The computer leaves this power energized for a while to power the burnoff relay.
You might have someone using that power for an accessory with a sneak circuit going into the ignition.
For instance, a stereo amp needs 12 volts from the battery, and is also switched on by ignition volts coming from the ignition/accessory switched power. A failing or overheated amp might have a blown diode or something..... or whatever is added to your electrical system.
To 84 Just wont quit!
