58mm Throttle Body Fitment
1996 LT1
Thinking of installing a BBK 58 mm TB and am wondering how you guys deal with the MAF to TB accordian which'll have a smaller diameter.
I had a heck of a time getting the stock accordian to fit on a 52mm TB I installed on my 415 L98. So I'm hoping NOT to have deal with the same problem again.
Thanks,
Jake
Thanks,
Jake
"I'm hoping NOT to have deal with the same problem again."
You will if you stay with the stock accordian piece you will have to deal with it.
Most upgraders are pre-stretching the piece before installing it ~ others are just replacing it.
A little lubrication should do the trick for this tight fit!!!!
Apply a little silicon grease to the rubber coupler and it should slip right together........
Worked for me......
Edit: I actually have the Edelbrock 58mm
Worked for me......
The stock air intake fit the 58mm TB on my 95 but on Scranage's 92 the 58mm TB wouldn't fit on the stock air intake So if you have a later LT1 I bet it will fit fine. 58mm
Stock
Checking to see if it will work (it was a cold day in colorado (in the teens) the camera was balky the rubber stiff and if fit fine.)
Stock
Yep, I have a 96 LT1 setup: I should have listed that in my original post, knowing how some guys are about that little detail.
Heating and spraying lubricant on the 86 accordian didn't help me much. That's why I discounted it for my 96 project.
From the feedback I've received, now I'm going to order a BBK 58mm unit (UNLESS YOU GUYS ADVISE OTHERWISE), and first try the stock accordian.
If it fails, I'll try the Home Depot 4"to 3" reducer plumbing piece. If that doesn't work, I'll go with an aftermarket connectors.
Thanks for all the responses.
Jake
Jake
St. Jude Donor '03 & '05
Jake
Jake
I had one on hand years ago, but returned because I didnt want to do the wireing thing thinking there was a better way. It wouldnt have made any difference on the TPS. But, I use a AS&M 58MM, and it is beautifully crafted.
But, I have heard BBK's have idle issues due to quality control, and that is not the area you want to be bad, with a high end big engine, when tuning will be needed.
Steve
I have a thred of what I did somewhere. WIll look it up. Also, will look for the IAC mod.
The ACCELL needs just the TPS mod.
Follow this thread. http://members.***.net/chipsbyal/page/index.html
Its in his LT1/4 mods, "Improve your idle"
http://forums.corvetteforum.com/show....php?t=1404085
had the same issue with my accell 58mm throttle body. i heated up some water to a boil in a pan, took the pan out to the garage and stuck the throttle body end or the duct in the water till it was softened up and slipped it right on. i split my old one at the seam thrying to put it on cold.
BBK Throttle Body
I heated up the stock accordian boot with a hair dryer to soften it and then pushed it on my Holley 58mm.
Also,speaking of throttle bodies,I have owned 2 Holley billet throttle bodies,52 and 58 mm,and have problems with throttle blades binding when hot on both units. Also have erratic idle issues. I would not recommend buying Holley throttle bodies. I also had to modify the TPS area on both units to get the TPS to fit. Look great-work like crap.
Just my 2 cents
Jim B.
Just my 2 cents
Jim B.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My solution is to return the TB to sender and get a stock one. Hopefully he takes it back after all this time.
The early C4s have a plastic accordian duct, not rubber, and heat/lube does virtually nothing to help it fit. To top it off, they have a lip on the end of the throttle body. I think this is a BBK copy.
i must disagree with that statement about heat that CC made. if the plactic duct is heated the material will become softer and have the ability to stretch to alow it to slip over the lip of the throttle body.
lube wil do nothing to help the duct stretch which is what is need to get it to fit.
No, the AS&M uses the factory one. The only mods I did to it were the IAC passage way mod to ensure the air flow into the LT1 manifold was identical to the factory, and BlueWasp found out the throttle body need to be excavated a little to get WOT.
Thanks for posting that last link Steve. I have a ASM Monoblade and I have not been able to reach WOT while having it idle low and sit on the idle adjust screw or vice versa. I've been looking at the pictures and can' quite figureout how far down you went. Could you approximate? Also, how did you keep the same angle?
I must be lucky I have an old BBK 58MM and zero idle issues. (I was looking for an excuse for a AS&M since they look so sweet) I've read a lot of bad things about the Holley which I find strange since their quality if usually pretty good.
Jake tell us how it turns out!!
The difference in inlet size is HUGE when counting that extra lip that sticks up on the aftermarket tb.
I have a BBK 58MM TB on my 88GTA and it took some lube to get the factory accordian to fit over it.
1/2 inch from the left to about 5/8 inch on the right, going from the center where she bolts to the throttle body to the right where the cable comes in from the driver. I put the white on there to show where I cut in relation to the center valley.
The angle isnt perfect but I used a dremel and went slow, did a little at a time, then checked till it was WOT and came all the way back.
I am sure if you knew someone with a more precise tools it would look better. Mine is more function, and I have a spare.
You could probably use a small round file and work it smooth. The white ont he side gives you an idea of the angle. Also, the AS$M is aggressive on there throttle angles, so a little grinding isnt going to hurt any performance.
