TPS adjustment... what the heck?
Old Sep 1, 2007 | 04:15 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Default TPS adjustment... what the heck?
All the guides to adjusting the TPS sensor voltage simply say that you "rotate the sensor." I do not see any way of doing this. The sensor only bolts down one way. Does anyone who has done this have any clarification?
Old Sep 1, 2007 | 04:40 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
I didn't think the TPS was adjustable on the LT4... I thought all that was monitored by the computer.
Old Sep 1, 2007 | 05:50 PM
LouisvilleLT4
Aww shoot. I wondered today if that was the case. My idle voltage reads too high at .63 volts, is there anything I can do about that?
Old Sep 1, 2007 | 06:01 PM
williammackean
St. Jude Donor '07
.63 doesn't sound too high, from what I have read on here.
I think it should run ~.6 closed to ~4.5 WOT.
Why do you think the TPS is out of adjustment?
Old Sep 1, 2007 | 06:10 PM
blackbear bob's Avatar
blackbear bob
Old Sep 1, 2007 | 07:12 PM
LouisvilleLT4
Really? I thought everybody was real particular about setting theirs to exactly .54 for optimum throttle response.
Old Sep 1, 2007 | 07:47 PM
mikey whipreck's Avatar
mikey whipreck
That's the case for my L98. Also on mine, the TPS rotates by loosening the two torx screws holding it in places at moving it clockwise or counterclockwise a few degrees.
It sounds like the LT4 setup is completely different..... Can you look at a FSM for your year? Whats it say?
Old Sep 1, 2007 | 08:29 PM
Carpenter's Avatar
Carpenter
It's a non adjustable TPS. Either: 1) the wiring between TPS and PCM is faulting........2) PCM circuit is faulting.....or 3) TPS itself is faulting.
I'm having a similar problem, except pulling a 'TPS high voltage' code (new tps that reads like my old one....which is actually LOW voltage .36V to 3.8V).....so I must assume it's either my connections (wires) OR it's my actual PCM.
Old Sep 2, 2007 | 12:24 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
L98 are adjustable, you'll need to get a new one if faulty...
Old Sep 2, 2007 | 12:44 AM
Trog's Avatar
Trog
NOT all L98 are adjustable. My '90 does have a tiny bit of slop in the bolt mounts that you can adjust about 1 degree but even according to the factory service manual... not adjustable.
Old Sep 2, 2007 | 09:22 AM
LouisvilleLT4
So the next question is, does it matter if the idle voltage is exactly .54 on the non-adjustable TPS sensors, or is the computer capable of accomodating itself to any idle voltage, like say .63 volts?
Old Sep 2, 2007 | 09:46 AM
Road Agent's Avatar
Road Agent
.63 is fine don' worry about it.
Old Sep 2, 2007 | 03:59 PM
JAKE's Avatar
JAKE
I agree.
In fact, on the 388 LT1 engine I just built, I elongated the slots on my TPS and adjusted mine to .67 because that's what Bryan at PCMFORLESS recommended when he reprogrammed my PCM.
On earlier engines that have the adjusable TPS, there is a range within which the voltage is acceptable. .54 is only the mid-point. From memory, I believe the range is +/- .075
On my 86, which has an adjustable TPS, the engine responded better set on the "high" side; .61/.62
Jake
Old Sep 2, 2007 | 05:31 PM
mikey whipreck
bingo
Old Sep 2, 2007 | 05:51 PM
SunCr's Avatar
SunCr
Everything GM built from at least '95 through today uses a non-adjustable TPS and all that I've worked on have an installed, closed throttle spec of .62 volts. Some when, replacing, require a special procedure with a bi-directional scanner. Unless you've got a TPS code (and you shouldn't with that reading), there is nothing to worry about. What are you trying to resolve?
To TPS adjustment... what the heck?
