Wiper help
Old Sep 3, 2007 | 10:08 AM
calpbs's Avatar
calpbs
Default Wiper help
I removed my pulse circuit board during a recent motor swap. Now after re-assembly the wipers do not appear to work. Have I lost a part? Is there a removable pin I am missing. Is there somewhere I can look and see how this should go together? This is very exasperating.
Old Sep 3, 2007 | 10:30 AM
Keystring's Avatar
Keystring
Have you checked it with a volt meter to make sure it's getting 12volts?
How about the fuse? Is it ok?
Old Sep 3, 2007 | 11:01 AM
calpbs's Avatar
calpbs
It is getting power, it is not rotating correctly and I think it is the pulse circuit board is not adjusted to the wiper motor correctly.
Old Sep 3, 2007 | 12:27 PM
Keystring's Avatar
Keystring
Did you cycle the motor before you attached the control arm?
You need to cycle the motor a couple of times so it 'parks' in the correct position when you shut it off. Then attach the arm and it should be right.
Old Sep 3, 2007 | 02:08 PM
calpbs's Avatar
calpbs
There must be something wrong somewhere else because I have done that as well.
Old Sep 3, 2007 | 02:14 PM
calpbs's Avatar
calpbs
To Wiper help
