Help me understand this Datamaster Scan
Old Sep 4, 2007 | 08:54 PM
Big Willy's Avatar
Big Willy
Default Help me understand this Datamaster Scan
Forum,
I’m new to ECM/PCM scanning. This is my first. I’m looking for inputs on my Datamaster Scan (Version 3.5.1). This scan was all done at idle. I uploaded 3 pictures with the beginning, middle, and end of the scan. In the beginning all is smooth until my spark advance goes nuts and the idle gets rather unsteady.
Car:
89 Coupe All Stock
Problem:
After the car warms up for a minute the idle is rough. Constant rise and fall. Vibrations
What I notice in my scan:
AFGS is High…..7.7 – 11. Should be 4 – 7.
Spark Advance goes nuts… Rapid and constant flucuations
L and S Term Counts drop. S returns but L stays at 108…. Should be 118 – 138.
O2 Volt goes nuts…Rapid and constant flucuations.
I’ve given this to you guys because I don’t know exactly what it’s telling me.
Any Theories?
Big *****
Old Sep 4, 2007 | 09:08 PM
tequilaboy's Avatar
tequilaboy
Can't see the pics. Only red x's here.
Old Sep 4, 2007 | 09:10 PM
Big Willy's Avatar
Big Willy
Sorry about the pictures. I don't know what happen. I inserted links. Copy and paste these links into your browser to view. I can't seem to upload the pictures. Sorry Again.
http://www2.snapfish.com/slideshow/A...34/t_=34584634
Old Sep 4, 2007 | 09:58 PM
JackDidley's Avatar
JackDidley
Big, the O2 #s are supposed to do that. The 108 on the blm means its running rich. Does the exhaust smell rich ?? The screen shots in open loop dont tell much. Its closed loop that counts. Maybe some one else has some ideas. I am thinking maybe leaky injectors or FP regulator. Have you checked fuel pressure?
Old Sep 4, 2007 | 10:06 PM
tequilaboy's Avatar
tequilaboy
The snap shots don't reveal too much information, but here's the obvious:
It appears to be pretty rich in closed loop with the BLM sitting on the 108 lower limit. The ecm is doing all it can to pull fuel.
The MAF flow also appears to be a bit high but not terribly so (it appears to be 8.4 gm/sec at 750 rpm), which is also consistent with the rich blm. I normally expect to see about 1 gm/sec/100 rpm. Too much measured airflow results in too much fueling. The low blm is trying to compensate for this.
Go for a drive at various speed and load conditions and get some data to fill in the histogram. This will give you a good idea if its running rich or lean overall.
If its rich everywhere, consider reducing the fuel pressure by a psi or 2 and re-evaluate.
Old Sep 5, 2007 | 06:12 AM
Big Willy's Avatar
Big Willy
The car is running rich. I knew that before I scanned it. I can smell it. I don't know what could cause it. I figure I have one key problem which is causing several readings to be out of tolerance. Question is "What's the Key Problem"
* When I first start the car it runs smooth for a minute or two. Then after is warms a bit I get erratic idle and vibration.*
Vacuum is Good
EGR is Good
PCV is Good
Inspected and cleaned Plugs
Big *****
Old Sep 6, 2007 | 09:08 PM
mseven's Avatar
mseven
because it's only a snap shot it is near impossible to say, however I can say in Open loop it is a bit lean at 15.7. The shot of closed while displaying 108 blm shows a 800+ 02 reading. I know you stated 02 is moving quite a bit, but does it do that when in closed loop. If it is hanging around that 800 mark and not fluctuating rapidly, that could be a syptom of a bad 02 sensor which can cause a rich condition. Cross counts should be clicking off quickly, but, if not would be another reference point. Pulse width doesn't appear high, other questions would be where is the fuel pressure set at or has it been increased.
However my first guess from this amount of data, is to have a closer look at the 02.
Old Sep 16, 2007 | 01:06 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Check mechanicals. Check your IAC. It will not throw codes, but will just die, or run bad as many have found. Scanning only shows what the ecm is telling it to do. It will make your car run like its rich as extra air is coming in acting like a vacuum leak.
http://shbox.com/1/iac2.jpg
Old Sep 16, 2007 | 06:32 AM
Atok's Avatar
Atok
It doesn't sound like the O2 sensor to me because they are telling the PCM it's rich, which the owner says it is. Since it runs good in open loop off the VE tables my guess would be a bad MAF sensor? Hard to tell without comparing his scans to a known good one.
To Help me understand this Datamaster Scan
