Idle speed after timing reset
I reset the timing on my 90 vert to 6* BTDC. After hooking up all items, the idle has jumped up to about 1,000 r.p.m. I would appreciate input as to what needs to be adjusted. It was about 800 r.p.m prior to me re-setting the timing. The idle control screw on the throttle body is adjusted out to the point it does not touch the accelerator plate.
Thanks in advance for any ideas
A couple of years ago, I replaced the fuel pump, injectors, manifold gaskets (upper & lower), just additional information.
The spec for the timing is 6° BTDC. The idle speed is programmed into your chip, or prom and is not user serviceable. Changing the timing should not change the idle speed. It sounds as though you have a vacuum leak that needs to be taken care of. There is no "idle control screw". As I said the idle is controlled by the ECM. With your FSM at hand, from the tech tips, or one of the various members personal sites, follow the steps to set your minimum air adjustment and TPS voltage. With those properly set, you can see if you have a vacuum leak to chase or possibly an IAC problem.
RACE ON!!!
RACE ON!!!
I disconnected the EST as directed for setting timing. The screw on the throttle body does not even touch the butterfly plate.
The throttle body seems to functioning just fine.
I am going to inspect for throttle cable binding / adjustment, tonight.
RACE ON!!!
On my '85 there is a mess of vacuum tubes near the hold down bolt for the distributer. I had to move those tubes around a lot to get to that bolt to adjust my timing.
Assuming that your idle changed, and all you did was adjust timing, I would check those vacuum tubes in that area..
Yes, I meant the throttle stop screw. I did not literally mean the butterfly plates themselves, just the connecting plate lever that actuates the butterfly plates.
I will check all of the vacuum lines around the distibutor.
I would at this point do a minimum air set.This set of adjustments sets a base timing and a base idle speed not controlled by the ECM. I have the minimum air set adjustment instructions giving out by Gorden Kilabrew. If you want it PM me with you email address
How the idle changed with a timing adjustment eludes me. Why did you adjust the timing in the first place?
The idle stop screw should be touching the linkage. Minimum air is just that - a minimum amount of air flowing pass the butterfly which is necessary for the IAC to do it's job. The only way to open the butterfly is with the screw. Something ain't right - would prefer to know why you made the adjustment in the first place rather than suggest you do something that might make it worse.
I agree that it would be nice to know why he reset the timing in the first place. But now if he or some one had adjusted something other than the timing the IAC is not function right because it doesn't have the base setting to start with. I learned the hard way when I replaced my throttle body and adjusted the idle screw out of ignorance. I still say at this point it's the way to go to get every thing back to the basics then if it still idles high then trouble shoot farther.
If the throttle body is dirty then you may not be able to adjust any of it. If there is schmegma between the butterflies and the throttle bores, then the butterflies will never close to where they should be. The IAC can get jammed up with crud as well. This condition happens slowly over time, and it may not be what is causing your problem. But it's something that is worth checking if nothing else works.
Received 1,401 Likes
You need to take the TB off and clean it, then do the IAC reset. Procedure is on my site.
While I agree with you guys that cleaning the throttle body and adjusting the min air (even though I disagree with how to adjust it) will improve the idle... Why would it help the guy in this case?
His idle was fine, he screwed with the timing, now his idle is off. My first assumption would be that he knocked something loose while changing the timing. He messed with the idle stop screw, but I still don't see how that has any bearing on idle.
Maybe I just dont know that much about this system though. If I'm wrong, please point out where I'm wrong.
To all of those that I now have pondering as to why I reset the timing on my 90 vert. As I mentioned, I changed the intake manifold gasket due to an oil leak. When I pulled the distributor out, I had marked the back of the manifold as to where #1 plug wire. When I put the parts back together, I forgot to take a screwdriver and turn the oil drive gear back a little so that the distributor would drop in in the correct tooth alignment. I don't drive the vehicle much (16,000 miles in 7 years), so I decided to check everything out. I pulled the distributor, moved the oil drive gear and reinstalled the distributor. I disconnected the EST, loosened the distributor, set the timng to 6* BTDC, and reconnected the EST. The idle speed is now about 1,00o rpm and thus, my thread.
Rich
Rich
I will clean the throttle body, vist Vadar's site for the IAC adjustment, and follow up with everyone.
I did clean the throttle body when I pulled the mainifold off to replace the gasket and have only put about 5,500 miles on the vehicle since that time. I performed a little porting on the plenum housing just behind the throttle body (the two bumps at the bottom and around the edges, nothing elaborate.
I have inspected all of the vacuum lines for leaks, but everything appears to be connected.
Other than the idle, the vehicle runs strong.
