hi,
There is plenty of oil.
The light comes on from start up and stays on,
but not every time the engine is started.
I beleive this may be a known problem but would like
confirmation before I order the part.
Nick.
Nick I can't tell you how prevalent this is, but do know the one on my 93 went bad. There should be some diagnostic help in the FSM if you have one, I would do that before ordering the part, good luck.
My 92 would do that on occasion. I pulled the wire connector and cleaned the contacts on both the sensor and the connector and never had a problem after that.
The engine in my car was one of the LT1's that had leak issues with the front seal so there was a buildup of oil on the sides of the oil pan. Once I cleaned everything up, no more problems.
