Coolant temp problems
Old Sep 7, 2007 | 07:52 PM
FL87Z52's Avatar
FL87Z52
Default Coolant temp problems
I noticed that the last two days my coolant temp climbs up to 210-220 within a couple minutes of driving doesn't over heat just runs at those temps. I checked all my levels and there all where they should be. What could cause this? A vaccum leak maybe.
Old Sep 7, 2007 | 08:01 PM
engle1147's Avatar
engle1147
This is a very normal temp for a stock C4...the radiator fan does not come on until you get even hotter.
Old Sep 7, 2007 | 08:07 PM
FL87Z52's Avatar
FL87Z52
I know that the fan comes on at 225 and is always on when the air in on, but it didn't start get that hot that fast until the last couple days plus when the temps did get that hot they dropped off pretty fast once the car gets moving now it just says in the 215-220 range
Old Sep 7, 2007 | 08:09 PM
shop14's Avatar
shop14
change the thermostat
Old Sep 7, 2007 | 08:12 PM
FL87Z52's Avatar
FL87Z52
Thermostat and water pump are less then six months old. Radiator is only three months old
Old Sep 7, 2007 | 09:41 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Crawl under the front of the car and look up into the radiator inlet area. Make sure there isn't a plastic bag or other debris clogging up part of the radiator fins. These cars will suck the leaves right off the road when the fans kick on high.
Your right, 215-220 is too hot while it moving over 45 mph.
It should run in the 192 - 197 range with the factory thermostat.
Old Sep 7, 2007 | 10:02 PM
FL87Z52's Avatar
FL87Z52
It has a 160 thermostat. It stays about mid 180 at about 45mph
Old Sep 7, 2007 | 10:16 PM
RRT vette's Avatar
RRT vette
100%
Old Sep 7, 2007 | 10:24 PM
Da Mail Man's Avatar
Da Mail Man
Old Sep 7, 2007 | 10:27 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
How come the 160 thermostat doesn't make the car stay at 160F? It must be broken.
Old Sep 8, 2007 | 10:24 AM
FL87Z52's Avatar
FL87Z52
I started the car a let it warm up to 160 and grabbed the upper radiator hose and could fell the coolant flowing through so the thermostat is working
Old Sep 8, 2007 | 10:33 AM
runner140*'s Avatar
runner140*
Your ride is normal. If the normal temps bug you, try:
New radiator cap
New hoses, upper and lower.
New tstat. (160 degrees)
Full engine/radiator flush and replace with 50/50% of Dexcool and distilled water.
Pull your radiator and give it a good cleaning with a high pressure hose.
Purchased a "Big Mouth Air Dam".
At this point and after four beers and running six miles at the beach, I foreget what else.
Old Sep 8, 2007 | 10:55 AM
FL87Z52's Avatar
FL87Z52
Thanks for the advice like I said before radiator, water pump, thermostat, cap, and hoses are all under six months old. The reasons I'm thinking vaccum leak is because I can hear a hiss some where around the drivers side valve cover. The car also over heated about 2 weeks ago due to the alternator pulley falling off the car got to about 270 but there hasn't been any problem until now
Old Sep 8, 2007 | 07:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default temp
i concur with the fan picking up some debris. I shut the car off at work (white painted concrete floor) and noticed tiny leaf fragments falling out from under the car when the fan finally quit.
I'd check there first. Low speed air does not flow easily when debris can be the culprit.
Old Sep 8, 2007 | 07:49 PM
Da Mail Man
.....use LOW pressure water flow as ya don't want to bend any "fins".....
Old Sep 9, 2007 | 05:06 AM
toptechx6's Avatar
toptechx6
Unfortunately that could be the clue, you may have lost a head gasket. Try pressure testing the system to see if it leaks down or test for exhaust gas in the cooling system with the dye kit. Certainly hope I'm wrong, good luck.
Old Sep 9, 2007 | 02:22 PM
WW7's Avatar
WW7
I was thinking the same thing. When he said the temp went to 270 and then he had a hissing noise and overheating, my first thought was Head Gasket. I also hope im wrong....
Old Sep 9, 2007 | 07:52 PM
FL87Z52's Avatar
FL87Z52
I think I have discovered the hissing sound. I think it's coming from a intake manifold bolt the one on the back drivers side I think coolant is hissing from around it. I don't see anyway I can get to it without removing the runners. Also where can I pick up the dye kit?
Old Sep 10, 2007 | 04:14 AM
toptechx6's Avatar
toptechx6
Hope that intake leak turns out to be the problem. I think NAPA carries the combustion leak tester, but if not here is a link.
http://www.sjdiscounttools.com/ttibt-500.html
To Coolant temp problems
