Idling Problem
Old Sep 8, 2007 | 05:37 PM
89 Bob L's Avatar
89 Bob L
Default Idling Problem
89 Coupe automatic.
The car was running great. At a 1/4 tank, filled it up with premium (as usual) and took it home. The next day an idling problem started. It starts out ok (700 RPM), then after a minute or two it fluxuates from anywhere from 500-900 RPM. Checked some vacuum lines and they seemed ok. Any suggestions? A vacuum leak somewhere? Bad gas? The fuel pump seems ok and the tank is pressurized? I am puzzled.
Old Sep 8, 2007 | 05:46 PM
engle1147's Avatar
engle1147
I believe the term for the engine RPMs jumping around like that is called "hunting." Check/clean/adjust the IAC if the problem doesn't resolve its self soon.
Old Sep 8, 2007 | 06:03 PM
Da Mail Man's Avatar
Da Mail Man
.....the only thing that has changed was the tank of gas....could it have been contaminated?....any codes?
Old Sep 8, 2007 | 07:49 PM
89 Bob L's Avatar
89 Bob L
No codes. I am hoping it is the gas, but while I'm driving there are no issues. I just can't figure what it could be.
Old Sep 8, 2007 | 07:51 PM
Da Mail Man
....ck your pm's.....ps, what is fuel pressure?
Old Sep 8, 2007 | 08:15 PM
trackman44's Avatar
trackman44
Spray throttle body with carb cleaner inside and out. There should be a hole beside throttle plate ( this is the IAC passage ) and should be sprayed thoroughly to free up passage. Should idle fine after that.
Old Sep 8, 2007 | 08:26 PM
Da Mail Man
NO......if you are going to spray anything, use THROTTLE BODY CLEANER, not carb cleaner..
Old Sep 8, 2007 | 11:22 PM
Yellow2015's Avatar
Yellow2015
DO NOT USE CARB CLEANER
Old Sep 9, 2007 | 12:14 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Check your IAC. It will not throw codes, but will just die, aor run bad as many have found. Scanning only whos what the ecm is telling it to do.
http://shbox.com/1/iac2.jpg
Old Sep 9, 2007 | 02:58 AM
trackman44's Avatar
trackman44
Whats the difference between the two products? they both perform the same function.
Old Sep 9, 2007 | 07:26 AM
Da Mail Man
.......well, since you have to go to the store to buy one or the other, read the labels....
To Idling Problem
