Miniram Question.
Old Sep 10, 2007 | 12:16 AM
Tigger85's Avatar
Tigger85
Default Miniram Question.
Any input on a good cam choice...Im putting together a 383 and I dicided to go with the Miniram to replace the TPI (85vette).
Im going to port and polish the stock heads, use the stock 48mm TB and 30lb injectors, 3:73 gear ratio, no cat, 40s Flowmaster, new chip.
Comp cams, TPIS, lPE??! what lift and duration...lobe etc...
Old Sep 10, 2007 | 12:30 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Theres a few guys on here that used the Miniram so Ill let them answer your questions with better advise...that being said,are you sure you want to use the stock 85 Iron heads,even with a port and polish?
Or do you have someone who can port them out and make them flow really well?I cant recall the last time I seen anyone using them heads ported out making nice power numbers.Just asking if youre sure you want to go this route.
Old Sep 10, 2007 | 12:56 AM
Tigger85's Avatar
Tigger85
Yeah I have a friend that says he can make them flow really well.
Old Sep 10, 2007 | 02:25 AM
vader86's Avatar
vader86
I think its a waste with the iron heads.
Theres no way he can make them flow what the 383+MR will need.
Old Sep 10, 2007 | 04:07 AM
CorvAdel's Avatar
CorvAdel
Ball park figure....what flow numbers will he need....?
Old Sep 10, 2007 | 07:58 AM
mseven's Avatar
mseven
190-195 head, w/numbers around 260-275 at 550, I would consider a cam in the 220/230 ish @50 duration a good choice (c.c.276).
Old Sep 10, 2007 | 09:06 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I think you would be better off doing it the other way around. Heads and cam now, Miniram later if it's a money issue. You didn't say if you are auto or stick but pick a cam with the Mini in mind. AFR 180 or 195. Probably 195 for the future.
Old Sep 10, 2007 | 03:31 PM
Tigger85's Avatar
Tigger85
Okay guys thx for the info..Its and auto, and money is an issue lol.
TPIS told me not to bother with 30lb injectors unless i upgrade the ECU with a DFI? Anyone use this? This fairly easy to install on a 85 vette?
I think ill go ahead and get new heads then just might set me back another month er 2, unless I find a really good deal. Ill shoot for the 195's.
Old Sep 10, 2007 | 03:59 PM
JAKE's Avatar
JAKE
GOOD DECISION. Because the cast iron heads have very thin port walls which don't allow much metal be removed (ask me how I know). So flow improvement on those anemic heads won't be nearly as much as you'll need.
Jake
Old Sep 10, 2007 | 04:07 PM
BADDUCK's Avatar
BADDUCK
They are right, 30 lb injectors are way too much. If your current injectors are good you can stay with them and install an AFPR for some fine tuning. You will want a custom chip at some point to get the best results from your upgrades.
Old Sep 11, 2007 | 12:03 PM
Tigger85's Avatar
Tigger85
So im looking at 400+hp...will the stock ECU be able to handle this if I can find someone to tune it? I really dont want to spend 1k on computer stuff. JAKE...you ported these before?
Old Sep 11, 2007 | 12:54 PM
Demonic85's Avatar
Demonic85
I bought Edelbrock Performer heads for my '85 and theres a big difference in power and thats all I changed at the time. They're aluminum and can be ported to flow as much as AFR heads. My set with new ARP bolts cost about $1200. The AFR's will run you close to $2000.
Why only a .275 lift? Thats not much higher than stock.
Old Sep 11, 2007 | 01:05 PM
vader86's Avatar
vader86
A DFI setup is not required, that part is incorrect. A custom chip is required.
Ask your chip maker what size injectors you should run, they will be the one calibrating it. Some may recommend 24, some might go as big as 30. So ask them.
Old Sep 11, 2007 | 06:09 PM
Curveit's Avatar
Curveit
I don't think you can get Edlebrock heads to flow as well as the AFR heads. If you could get it to flow those numbers (286 CFM); providing there's enough material; they would probably be "hogged out" so big it would affect low and mid-range power. AFR 195 CC heads will support 600 HP, and cost $1450-1500 in ads I've seen.
Old Sep 12, 2007 | 02:22 PM
Tigger85's Avatar
Tigger85
Where is the bst place to find them at a good price?
Old Sep 12, 2007 | 04:12 PM
BADDUCK's Avatar
BADDUCK
Try www.flatlanderracing.com #1040 195 street heads $1440
Old Sep 12, 2007 | 08:02 PM
Tigger85's Avatar
Tigger85
check out these Dart Iron eagle heads 200cc...seems like for the price they flow just as good as AFR 195's? Half the price...am I missing something other than them being alum? http://www.dartheads.com/manager/upl...IRON%20SBC.pdf
To Miniram Question.
