newbie needs help
Old Sep 11, 2007 | 05:06 PM
barryboy's Avatar
barryboy
Navigator
Default newbie needs help
I've read every part of my Chilton's...Can anyone please tell me how to:
a) check if auto trans on a 95 LT1 is downshifting correctly
b) check if a head gasket is blown
c) check if the engine temp gauge (not coolant temp sender) is working correctly
Thanks!
Old Sep 11, 2007 | 07:03 PM
Da Mail Man's Avatar
Da Mail Man
Thanks!
....you need to purchase a HELMS SERVICE MANUAL if you plan on keeping the car!..
Old Sep 11, 2007 | 07:22 PM
engle1147's Avatar
engle1147
I don't have the FSM for your car.....but I'm sure someone will chime in......welcome to the forum!
Old Sep 11, 2007 | 07:37 PM
Da Mail Man
.....oh yeah, i forgot......welcome to the jungle!
Old Sep 11, 2007 | 08:16 PM
CFI-EFI's Avatar
CFI-EFI
Keep that Chilton's Manual for a door stop or a wheel chock. As previously stated you are going to need a FSM (Factory Service Manual) as published by Helm Inc. for Chevrolet.
However, your questions are somewhat generic, not Corvette specific.
a) Automatic down shifts are somewhat intuitive. Is your trans giving you cause for concern? Other than a subjective test drive, the FSM likely has line pressures listed for different conditions that you can verify. Your transmission is computer controlled.
b) Oil in the water. Water in the oil. Water leaking at the head to block junction. A compression test and a CO in the coolant test, come to mind.
c) Disconnect the wire to the gauge from the sender, then ground the wire that goes to the sender. Open circuit, the gauge should read the minimum, low, or cold. Shorted, to ground the gauge should read full scale.
RACE ON!!!
Old Sep 11, 2007 | 09:07 PM
aminnich's Avatar
aminnich
c--simple--compare the analog gauge to the digital. There are separate circuits and senders. digital should be slightly higher than the analog.
Old Sep 12, 2007 | 10:13 AM
barryboy's Avatar
barryboy
Navigator
Thanks for your help! I'll check it out and let you know.
Old Sep 12, 2007 | 10:40 AM
dclafleur's Avatar
dclafleur
1. It is computer controlled and should feel like it is shifting correctly, if it feels like there's a problem it might be a good time to change your ATF, I find most people neglect this on their automatic transmissions.
2. Check for water in the oil, do an oil change, give you a good opportunity to check and perform maintenance that needs to be done anyways. Also check for oil in the coolant.
And to reiterate what everyone else has said, get a factory service manual from helms. They are a bit pricey but really the best reference to have.
Old Sep 12, 2007 | 10:49 AM
billybonesmusic's Avatar
billybonesmusic
[QUOTE=CFI-EFI;1561875744]Keep that Chilton's Manual for a door stop or a wheel chock.
the link doesn't work, here.........
http://www.helminc.com/helm/homepage....php?t=1809441
Old Sep 12, 2007 | 11:02 AM
CFI-EFI's Avatar
CFI-EFI
You are right. I had a "dot" where there shouldn't be one. I fixed it. Thanks.
RACE ON!!!
Old Sep 12, 2007 | 11:10 AM
billybonesmusic
no problem, i know you have been providing these links for awhile now, and i MUST admit, because of your links...i just ordered my FSM today, OK, I'm a slacker! but with this forum and its awsesome mechanix, does one REALLY need one? he he, YEP!
Old Sep 12, 2007 | 07:54 PM
CFI-EFI's Avatar
CFI-EFI
Better late than never. If you will study it and use it, you will come to wonder how you got along without it.
RACE ON!!!
Old Sep 12, 2007 | 07:57 PM
Da Mail Man
RACE ON!!!
cfi, you forgot the below illustrated/animated icons;
Old Sep 12, 2007 | 08:03 PM
CFI-EFI's Avatar
CFI-EFI
You, TOO are right. Another welcome correction! Further proof, that it takes a village...
RACE ON!!!
Old Sep 12, 2007 | 08:16 PM
Da Mail Man
RACE ON!!!
....."village"?.......huh?
To newbie needs help
