Starting Problems
Old Sep 10, 2007 | 10:34 PM
Hard Drive's Avatar
Hard Drive
Default Starting Problems
I have an '84 4+3 with starting problems. The car will start normally and idle well. I can turn it off after it has run for five minutes and it will not restart. The starter turns the engine fast, interior dash light come on but the engine will not start. I have installed a new coil and ignition pick-up module. Does anyone have any suggestions?
Old Sep 10, 2007 | 10:48 PM
RRT vette's Avatar
RRT vette
Have you checked for spark at the plugs? See if the injectors are spraying fuel? Checked fuel pressure?
Old Sep 10, 2007 | 10:50 PM
Hard Drive's Avatar
Hard Drive
How do check the fuel presure on an '84?
Old Sep 10, 2007 | 10:56 PM
Hard Drive's Avatar
Hard Drive
I will check the spray. Thanks
To Starting Problems
