Timing and knock issue.
Old Sep 10, 2007 | 11:32 PM
Dads90's Avatar
Dads90
Default Timing and knock issue.
I have jacked with the timing for months trying to retard a knock issue. I have started this thread hoping others might join in with my issue. The knock has occured when the car is warm and idling. I notice that when the knock occurs the car is idling a little rough, I can feel the knock thru my stick shift, and hear it (kachunk,kachunk)every 8-10 seconds. It used to get bad like every 2-4 seconds, I since replace fuel injectors, distrib, wires, and upon advice from our company mechanic move the timing to 10* BDC and actually seemed to help. Due to an idle issue, under cool conditions, which has been resolved with members help, I moved the timing back to 6* BDC. I noticed the knock is reoccuring. Its funny it doesn't occur but only occasionally. Its a faint kachunk sound and one every 10 seconds or so. Now, if I turn on the AC it doesn't seem to occur. I'm running a 8.5* BDC now and I will monitor the sound, heck I don't even listen to the radio, just listen for the knock when stopped.
Old Sep 11, 2007 | 01:10 AM
ultraviolet70's Avatar
ultraviolet70
I'm gonna guess the car's a six speed. Since your feeling it through the shifter I'm gonna think you might have a failing D.M. flywheel.
Old Sep 12, 2007 | 11:37 PM
Dads90's Avatar
Dads90
ttt
Old Sep 13, 2007 | 07:41 PM
CFI-EFI's Avatar
CFI-EFI
Your description of the noise is not that of spark knock or detonation. Use a stethoscope or a big screw driver to your ear to listen all around the engine in search of the source of the noise.
RACE ON!!!
Old Sep 13, 2007 | 11:18 PM
Dads90's Avatar
Dads90
RACE ON!!!
Wouldn't the noise be a constent ? I can go a couple of days without a sound. I noticed that the idle speed being around 725 rpm the sound has reocurred. When it was around 1000 rpm the sound never was heard. I will listen with a screwdriver this weekend.
Old Sep 14, 2007 | 10:29 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
RACE ON!!!
It sounds as if something is not bolted up tightly. I think the timing / rpm changes are just masking the problem by putting the engine in a state where the "knocking sound" isn't happening. By turning on the A/C, idle speed is added & timing changes (with the additional load), so the sound is once again masked.
I'd set the timing correctly, turn off the A/C, and let the noise occur so you can find it. Failing DM flywheel? Loose engine mount? Loose starter? Something is not tight...
Old Sep 14, 2007 | 11:12 AM
CFI-EFI's Avatar
CFI-EFI
I would expect a spark knock to be consistent, but I wouldn't expect a spark knock or detonation too occur at a steady low speed or at idle under no load. Plus adding timing will aggravate a spark knock problem, not alleviate it. It sounds to me as though you have something that is rattling or vibrating and that the different idle speeds set up varying harmonics that change when you do or don't hear it.
RACE ON!!!
Old Sep 14, 2007 | 11:30 PM
Dads90's Avatar
Dads90
I did notice the belt tensioner bounces when the knocking occurs. I thought it was making the noise so it was replaace with a new one. The noise isn't as prevelant. I think I will go back to 6* BDC and listen closely. Thanks guys I will be experimenting this weekend and will post back.
To Timing and knock issue.
